3 Replies Latest reply on Sep 5, 2014 3:57 AM by Artur Kiraga
    how to animate tank treads in 2D picture?
    eiknachui Level 1
      hi
      I have a .psd picture of a tank and try to animate it in AE by rotating its wheels and tread (or track?). The only solution i have come up with is to slightly change tread layer's x and y positions in every frame, making it to vibrate. However it does not create rotation illusion which i'm after - the tread vibrates, but doeas not revolves around the wheels.
      If there are other solutions to make tread layer rotate around tank's wheels, i would be glad to hear about them.
      All 7 tank's wheels are separate layers and the tread layer is above them. The rest of the tank's layer is above tread layer
      thank you
        • 1. Re: how to animate tank treads in 2D picture?
          One idea:
          Animate a piece of the tank tread following its path at an even speed (roving keyframes will help). Use the loopOut expression so that it loops. Make enough duplicates and offset them in time so that you have a full tread movement. If you need to adjust the speed of this, precomp the whole set of tread layers and use time remapping.
          • 2. Re: how to animate tank treads in 2D picture?
            Draw a mask path to mimic the tread shape , copy&paste it to the one of the tread link's position, enable 2D auto-orient on the layer. Takes about 10 nanoseconds. Then duplicate the layer and offset the timing. Add some wiggle to add a slight variatikon if necessary.
            Mylenium
            • 3. Re: how to animate tank treads in 2D picture?
              Artur Kiraga Level 1
              I know it's late....
              but since it's a 2D front view, i would try and make a solid layer, put a VEGAS effect on top of it, draw a mask around the tanks track, then probabely do the whole animation of the tank
              wheels and track (its a mask so you can animate separate vertex points). And when the whole animation is set and done i would precompose the track solid layer and move the
              mask and effects to the PRECOMPOSED layer. Now back in the original layer i would put some effects (bevel emboss?) on the precomposed track.
              I think you could skip the vegas and mask effect and do the shape layer with segemented stroke animation.
              But VEGAS does give nice effect in this case.
              yeah i know it's late
              artur
