0 Replies Latest reply on Feb 3, 2014 1:31 PM by SimeonC
    Problem with mail in CF8
    SimeonC
      Hi All.
      I have a problem with a CF8 install that a client has in that I cannot connect to a SMTP server to send mail through it. Description as below.
      Setup:
      Tomcat 6
      CF8.0.1
      Java 1.6.0_24
      Windows Server 2008 R2
      Problems:
      • In CFAdmin I cannot verify that the email settings are correct, even though they are. I tested the settings using telnet and sent mail fine.
      • Attempting to actually send an email with the correct settings - through cfmail attributes - gave the following error:
      "Error","scheduler-1","01/31/14","17:03:52",,"smtp"
      javax.mail.NoSuchProviderException: smtp
                at javax.mail.Session.getService(Session.java:611)
                at javax.mail.Session.getTransport(Session.java:541)
                at javax.mail.Session.getTransport(Session.java:484)
                at javax.mail.Session.getTransport(Session.java:464)
                at coldfusion.mail.MailSpooler.getConnection(MailSpooler.java:991)
                at coldfusion.mail.MailSpooler.deliver(MailSpooler.java:832)
                at coldfusion.mail.MailSpooler.sendMail(MailSpooler.java:753)
                at coldfusion.mail.MailSpooler.deliverFast(MailSpooler.java:1114)
                at coldfusion.mail.MailSpooler.run(MailSpooler.java:1024)
                at coldfusion.scheduling.ThreadPool.run(ThreadPool.java:201)
                at coldfusion.scheduling.WorkerThread.run(WorkerThread.java:71)
      Last time I had this problem on the server I fixed it by following the instructions here: http://www.coldfusionmuse.com/index.cfm/2012/5/4/Able-Commerce-5-on-CF--Email-Problem but this time it hasn't worked! Sadly I don't have a backup from when I fixed it last as this is our staging server on amazon which got deleted while I was on holiday and I had to rebuild it from our live server.
      Any help would be greatly appreciated as I'm approaching insanity on this one!!
      Thanks, Simeon.
