8 Replies Latest reply on Feb 5, 2014 11:32 AM by jackley923
    Rotate symbol based on cursor angle
    jackley923
      Hey There,
      I am trying to get a symbol to rotate and follow based on the cursor angle and I am running into an issue I can't track down. I am using sym. to decalre my variables so that I can reference them globally whithin my composition. But it looks like its something wrong with the diffAngle function.
      Any thoughts?
      Here is the code on get composition ready:
          sym.x = e.pageX;
          sym.y = e.pageY;
          sym.centerItem = sym.getSymbol("mySymbol");
          sym.centerLoc = centerItem.offset();
          console.log( 'Center Item =' + sym.centerItem);
          console.log( 'Center Loc =' + sym.centerLoc);
      function diffAngle(){
          sym.dx = sym.x - (sym.centerLoc.left + (sym.centerItem.width() / 2));
          sym.dy = sym.y - (sym.centerLoc.position().top + (sym.centerItem.height() / 2));
          sym.newAngle = Math.atan2(sym.dy, sym.dx) * (180 / Math.PI);
          return sym.newAngle;
          console.log( 'New Angle =' + sym.newAngle);
      $('#Stage').mousemove(function(e){
          sym.myAngle = sym.newAngle;
          sym.rotationValue = 'rotate(' + sym.myAngle + 'deg)';
          sym.$("mySymbol").css({
              '-moz-transform': sym.rotationValue,
              '-webkit-transform': sym.rotationValue,
              '-o-transform': sym.rotationValue,
              '-ms-transform': sym.rotationValue,
              'transform': sym.rotationValue
          console.log('Mouse Moving');
        • 1. Re: Rotate symbol based on cursor angle
          jackley923 Level 1
          If you copy the code, create a symbol named mySymbol, and paste the code into the get composition ready to see the error I'm getting. No matter how I restructure things I can't seem to nail it
          Javascript error in event handler! Event Type = element
          And I copied the wrong function here is the one I'm using:
          I was playing around with position() and thats why it was removed from the first post
              sym.dx = sym.x - (sym.centerLoc.position().left + (sym.centerItem.width() / 2));
          • 2. Re: Rotate symbol based on cursor angle
            TimJaramillo Level 4
            Hey there, your code has a few issues.
            1st: to use props like "offset" and "width", you can't use Edge symbols, you have to use the raw object- I use jQery for this.
            2nd: you need to set the mouse position vars (sym.x, sym.y), in the mousemove function.
            example:
            www.timjaramillo.com/code/edge/rotateSymbolToMouse
            source:
            www.timjaramillo.com/code/edge/_source/rotateSymbolToMouse.zip
            And code (pasted in Stage.compositionReady):
            sym.x;
            sym.y;
            sym.myAngle;
            sym.newAngle;
            sym.centerItem = sym.$("mySymbol");
            sym.centerLoc = sym.$("mySymbol").offset();
                sym.dy = sym.y - (sym.centerLoc.top + (sym.centerItem.height() / 2));
                sym.x = e.pageX;
                sym.y = e.pageY;
                sym.myAngle = diffAngle();
                //console.log('Mouse Moving, sym.myAngle = '+sym.myAngle);
            • 3. Re: Rotate symbol based on cursor angle
              jackley923 Level 1
              I see the revisions in the code, focusing on sym.myAngle = diffAngle();
              I was wondering if you could make a varible equal a functions output but was getting errors so I stripped it down to zero in on things so thanks for showing me that.
              and for showing me that I needed to delare
              sym.myAngle;
              sym.newAngle;
              with
              sym.x;
              sym.y;
              and move
              sym.x = e.pageX;
              sym.y = e.pageY;
              to the mouse move
              The funny thing is when I change all my code to your new revised code I am still getting the same error ... but once I copy and paste yours it works properly. For the life of me I can't see the difference but I am going to becasue I like to see me errors and where I'm going wrong so I don't make the same mistake in the future
              Thx Tim
              • 4. Re: Rotate symbol based on cursor angle
                No prob!
                When you're changing it versus copy/pasting, you may just be missing one tiny revision (it's hard for our human eyes to catch every little glyph in code).
                • 5. Re: Rotate symbol based on cursor angle
                  jackley923 Level 1
                  Totally! I figured it must have been that.
                  I wanted to yank out the mousemove function I created on compositionReady and put its contents on a Stage.mousemove created from the fly out menu in edge. But when I do that it no longer works...
                  I thought that both examples of calling the function for mousemove would funtion exactly the same...
                  I even tried referencing the diffAngle function in a different way, as I thought it was a scoping issue
                  sym.myAngle = sym.getComposition().getStage().diffAngle();
                  But all I get are a bunch of errors:
                  • 6. Re: Rotate symbol based on cursor angle
                    It's probably a scope issue.
                    But it's actually better practice to keep your code in one place anyway.
                    Edge Animate provides the different event panels but it's really just for ease-of-use. If your code is all in one place then you don't have to jump through panels wasting time trying to find code.
                    • 7. Re: Rotate symbol based on cursor angle
                      jackley923 Level 1
                      Yeah Good Call
                      Thx again Tim
                      • 8. Re: Rotate symbol based on cursor angle
                        jackley923 Level 1
                        And yeah it was a scoping issue, but now I see what it was
                        if I moved it out of the compositionReady then I needed to set up the function with sym. and reference it like so:
                        sym.myAngle = sym.diffAngle();
                        But after all that I am going the route of keeping it all ini one place
                        Thx Doooooode!
