2 Replies Latest reply on Feb 4, 2014 6:14 AM by JimHess
    Lightroom to photoshop no camera raw
    Jillian Xenia Level 1
      When i export raw,dng,tiff files to photoshop cc, camera raw never appears. I've tried tweaking settings, everything is updated. Why is this happening ???
        • 1. Re: Lightroom to photoshop no camera raw
          dj_paige Level 10
          There are other people reporting this as well in the Lightroom forum. As I don't use Photoshop, I don't know if a solution has been found. I suggest you search in the Lightroom forum.
          • 2. Re: Lightroom to photoshop no camera raw
            There is no need to go to the Camera Raw interface. Lightroom has all the same exact controls as Camera Raw does. When Lightroom sends an image to Photoshop, Camera Raw is simply used to interpret the Lightroom adjustments. The image is interpreted and then sent directly to Photoshop. If you want access to the Camera Raw interface you will have to open your images as smart objects and then go to Camera Raw from Photoshop.
            Added later: the workflow I described is what happens when you use the "Edit in Photoshop" option. You are talking about "exporting" to Photoshop. How are you exporting?
