1 Reply Latest reply on Feb 5, 2014 5:36 AM by resdesign
    Random Rotation on click
    npackey
      I have a banner I have been working on with three spinners like a slot machine.  Currently I have everything hand animated to rotate the spinners to spin to one of 4 options each.  What I would like is to have a button that triggers the spinners to rotate to a random ( 1 of 4 ) points over the course of 1/2 second 500ns.
      Is there a code snippit that will make an object rotate to one of 4 chosen variables?
        • 1. Re: Random Rotation on click
          resdesign Adobe Community Professional & MVP
          Hello; here is an example of a spinner I made. This is probably different from what you are doing but it will give you an idea of what you can do.
          var spinner1 = sym.$('spinner1');
          spinner1.click(function(){
          // randomize the degree of spin.
                    var myVar1 = Math.floor((Math.random()*180)+10);
                    //alert(myVar1);
                    sym.getSymbol('spinner1').play();
                    spinner1.css({
                              '-webkit-transform': 'rotate(' + myVar1 + 'deg)',
                              '-moz-transform': 'rotate(' + myVar1 + 'deg)',
                              '-ms-transform': 'rotate(' + myVar1 + 'deg)',
                              '-o-transform': 'rotate(' + myVar1 + 'deg)',
                              'transform': 'rotate(' + myVar1 + 'deg)',
             spinner1.css('-moz-transition','all 500ms cubic-bezier(0.420, 0.000, 1.000, 1.000)');
