I am working on an extension and I've hit a dead end. Looks like when the panel's icon is clicked, a window.loaded event type is fired. But what type of event is fired when you collapse the panel back into icon form ?
I want to link serialization to the window.unload or window.close event , but nothing of the like seems to be working, which means that such a event is not fired.
Any ideeas ?
Our next release of CEP will include support for programmatically resizing an extension and receiving events when the panel visibility has changed e.g. collapsed.
Kind regards,
Lea
I am also looking for the same thing. Is there any way, we can find that the panel is collapsed? And also, Is it possible to change the size of collapsed panel?
Thanks.
apparently there is no resize/collapsed event (see Re: com.adobe.csxs.events list).
However, you can try out the "onBlur"-Event, maybe this fits your needs. See Real focusOut event of the extension?
What are you trying to achieve? Maybe we can find a workaround for your use-case until this is officially supported.
@_VG‌: Resizing the panel is not possible anymore (it was back in flex days) - support for this is coming in the next release though according to this thread: Resize an extension Panel from script
Greets
Kind regards,
Lea
Hi Lea,
is the panel collapsed event missing in CEP6? Also, are any panel-related events available (event that fire when user resize, close, collapse)?
Thank you,
Davide
you could take a look at ''com.adobe.csxs.events.WindowVisibilityChanged' event. It seems to be working with panel type extension.
But not working at all with modal dialog type extension.
Thomas.
lesavage​ Could you be so kind to point me to documentation for the events that you mention in this old thread? Thanks
I believe the latest documentation is available at Adobe CEP · GitHub​. The following link might be a good starting point: CEP-Resources/CEP 9.0 HTML Extension Cookbook.md at master · Adobe-CEP/CEP-Resources · GitHub
Kind regards,
Lea
