4 Replies Latest reply on Feb 5, 2014 6:34 AM by Nando Darder Mallorca
    associate a file extension with my executable, how to receive filename?
    Nando Darder Mallorca Level 1
      Hi
      I'm using flaslh profresional to create this application:   Edit_epl.exe
      I install the application.
      I make a file association extension because I want to do this:  when double-click on a file with the extension ".elp" then runs Edit_epl.exe.
         example doubleclick on:  "my_sample.epl"  ---> then runs Edit_eplp.exe.   so far,so good.
      My question is how to know its filename (my_sample.epl) as "parameter" inside "Edit_eplp.exe"
      Can anyone help me?
        • 2. Re: associate a file extension with my executable, how to receive filename?
          Hello, Thank you!
          but I don want to do what this example do:
          The following code lets the user navigate to an MP3 file and open it in the default application for playing MP3 files.
          What I want is:
          (I change the example:)
          I want to click on a textFile  for example  hello.txt, with the content:   "My name is Fernando"
          1 - create an application   My_edit_txt.exe   (with only one text_field, MY TEXT)
          2 - install the application.
          3-  associate the extension txt  to my  editor: My_edit_txt.exe
          4-  when I click on hello.txt,
          5-  the system launches -> My_edit_txt.exe (so far works ok)
          6- then I dont know:  Inside My_edit_txt.exe:
          Which file clicked the user?
          if I knew the file I could read hello.txt and put the text "My name is Fernando" in the textfield MYTEXT.
          perhaps this example is better to undestand my question :-)
          thanks so much
          • 3. Re: associate a file extension with my executable, how to receive filename?
            moccamaximum Level 5
            As far as I kow what you are trying to do is not exactly possible.
            A workaround is to use a LocalConnection
            I used this FrameWork:
            http://flash.area-network.de/projekte/aslocalconnect/as3/eng/
            to pass systemvars to a multilanguage projector so that he would start up with the users system language active.
            You should be able to create an air application which you can drag&drop your my_sample.epl on and then the file name is used as a param to launch
            your Edit_eplp.exe with this file opened.
            • 4. Re: associate a file extension with my executable, how to receive filename?
              I solve it!
              Question:
              Resolution:
                 NativeApplication.nativeApplication.addEventListener(InvokeEvent.INVOKE, onInvoke);
              package silbo.esment.general.base_juegos
                        import flash.desktop.NativeApplication;
                        import flash.display.MovieClip;
                        import flash.events.InvokeEvent;
                        import flash.text.TextField;
                        public class Clip_editor_epl extends MovieClip
                                  public var t_texto:TextField;
                                  public function Clip_editor_epl()
                                                 super();
                                  function onInvoke(event:InvokeEvent):void {
                                            mitrace("on invoke");
                                            mitrace("arg="+event.arguments);
                                            mitrace("file to open:"+event.arguments[0]);
                                  function mitrace(trozo){
                                            if(trozo==null){
                                                      trozo="";
                                            t_texto.appendText(trozo+"\n");
                        }//clase
