2 Replies Latest reply on Feb 5, 2014 12:03 PM by MadMich
    Layers
    MadMich Level 1
      I am trying to show/hide a layer and a field at the same time.
      This is what i have so far but i'm stuck as the field doesn't do anything!
      var ocgs = this.getOCGs();
          for (var i=0; i<ocgs.length; i++)
      if (ocgs[i].name == "MyLayer"){
                  ocgs[i].state = !ocgs[i].state;
      this.getField("MyField").display = display.visible;
      }else{
      this.getField("MyField").display = display.hidden;
      Any pointers would be appreciated.
        • 1. Re: Layers
          Karl Heinz Kremer Adobe Community Professional
          Your field is actually doing something, but so fast that you may not see
          the effect. You are processing all layers in your loop, and whatever the
          last layer is determines if your field is shown or not. If your last layer
          is "My Layer", then you will see the field, if it's a different layer, your
          loop will end with the "else" path, and your field will get hidden. you
          need to modify the way your field gets shown or hidden:
          for (var i = 0; i < ocgs.length; i++) {
          if (ocgs[i].name == "MyLayer") {
          if (ocgs[i].state) {
          } else {
          In this case, you are only modifying the field display property when your
          loop is processing the "MyLayer" layer.
          Karl Heinz Kremer
          • 2. Re: Layers
            MadMich Level 1
            Thank you very much that worked a treat.
