2 Replies Latest reply on Feb 7, 2014 11:16 AM by Shadow50
    How do I tighten the space between lines in FormsCentral?
    Shadow50
      I have over 100 PDF fillable forms to create. I also need to be able to put some of them online so that is why I have chosen your program and it comes with Adobe Cloud version.
      I like your program for ease of use but there are a few flaws that should be addressed:
      I have multiple lines of text that need their own fill-in text field, but I do not need the label portion of the text field. This causes a lot of blank space and stretches the document over two pages. This is OK if it is an online form. But these forms are for print. I would like to be able to condense the form to one page.
      The program needs a blank text field with no label.
      Also needs line spacing adjustment capablity.
      Another issue that I have found with this program is the inability to adjust each text box to fit. Some of my labels are longer than others and some are shorter but I am not able to adjust the text to fit on one line. Should be able to set up the text boxes independently from the text box above it.
      Thank you.
