6 Replies Latest reply on Feb 6, 2014 2:01 PM by George_Johnson
    Dynamic Stamp
    lkpartee
      I am trying to modify a dynamic stamp to read something like this:
      "By Jane Doe on Feb 6, 2014 at 10:26am"
      This would be used to insert the current date and time at the time the stamp is applied to the document.  If it could pull the "Jane Doe" from the Preferences - Identity - Name field, that would be great too.  So far, I've only found something that pulled from the Login Name.  The only javascripts I've found had the date and time as a string.  I'm a little OCD and would like the word "at" between the date/time.  This would be used in a stamp that says something like...
      Plan Sheet Reviewed by Our Company
      STATUS:
      X Approved          X Approved as Noted
      X Revise per Comments and Resubmit
      Each of the "X's" represents a checkbox that would be checked to indicate whether the plan was approved or not.
      I have no real knowledge of javascript and would appreciate any help offered.  Also, if there are any tricks to making sure the file stays dynamic once it's saved, I would appreciate it.
      I'm using Acrobat 9 Pro on a Windows 7 machine.
