2 Replies Latest reply on Feb 6, 2014 2:55 PM by jason_clement
    Busy Cursor or Progress Bar
    jason_clement
      I have looked all around forums and links and am learning all sorts of things except for the one thing I need. I work for a publishing company and we produce a number of directories. I have modified the change/find script form adobe to pull these articles in from a tab-delimited text file. Everything works.
      Where I run into issues is trying to generate a progress bar or busy cursor. I have the progress bar from Peter Kahrel's Script UI for Dummies but can't seem to figure out how to determine the total number of lines in the file.
      Then I decided that the easiest thing would be to create a busy cursor and found this thread http://forums.adobe.com/thread/1109409. Problem solved... almost, I get an error stating "illegal use of reserved word import." This may be a Mac issue as the thread is a PC discussion.
      Could you help me figure out what I am missing? Solutions for Mac and PC are wonderful as I use CC on Mac at work and CS6 on PC at home.
      My code is below as I said the dirInput() function is working, with 5000+ entries it takes a little while to run so just need a progress bar or busy cursor. Thank you in advance. Jason
      import mx.managers.CursorManager;
      CursorManager.setBusyCursor();
      var doc = app.documents.item(0);
      var txtFrame = app.selection[0].parentStory;
      dirInput();
      CursorManager.removeBusyCursor();
      function dirInput(){
          var dirFile = File.openDialog("Choose the directory file you wish to import.");
          var txtLine, Lname, Fname, Phone, StreetNum, StreetName, HisEmploy, HerEmploy = null;
          Lcount = 0;
          if(dirFile != null){
              dirFile = File(dirFile);
              var myResult = dirFile.open("r",undefined,undefined);
              if (myResult == true){
                   //Loop through the find/change operations
                  do{
                      dirLine = dirFile.readln();
                      findTabArray = dirLine.split("\t")
                       //find options by tab
                      //>>> <tab 0> Last Name       <tab 1>        First Name       <tab 2>        Phone       <tab 3>        Street Number       <tab 4>        Street Name       <tab 5>        His Employment       <tab 6>        Her Employment
                      Lname = findTabArray[0]; //get the LastName - [0] tab
                      Fname = findTabArray[1];  //get the First Name - [1] tab
                      Phone = findTabArray[2];  //get  the Phone Number - [2] tabs
                      StreetNum = findTabArray[3]; //get the Street Number- [3] tabs
                      StreetName = findTabArray[4]; //get  the Streetname - [4] tabs
                      HisEmploy = findTabArray[5];  //get His Employment - [5] tabs
                      HerEmploy = findTabArray[6]; //get Her Employment - [6] tabs
                      //build and format the text line-by-line
                      txtLine = Lname + ", " + Fname;
                      txtLine = txtLine += "\t"; //add tab character
                      txtLine = txtLine + Phone;
                      txtLine = txtLine += "\n"; //add soft return
                      txtLine = txtLine + StreetNum + " " + StreetName;
                      txtLine = txtLine + HisEmploy;
                      txtLine = txtLine + HerEmploy;
                      txtLine = txtLine += "\r"; //add paragraph return
                      txtFrame.insertionPoints.item(-1).contents = txtLine; //>>> Inserts the entry at the end of the text already in the text frame.
                      }while(dirFile.eof == false); //>>> completion of the do…while loop – in this case the loop runs until it reaches the end of the file (.eof); once eof is reached close the directory file.
                      dirFile.close();
      function progressbar(line) {
          var w = new Window ("dialog", "Export XML", undefined, {closeButton: false});
          w.add ("progressbar", undefined, 1, line);
          var w = new Window ('palette');
          w.pbar = w.add ("progressbar", undefined, 1, line);
          w.pbar.preferredSize.width = 300;
          w.show();
          for (var i = 0; i < line; i++){
          w.pbar.value = i/300;
          $.sleep(20);
        • 1. Re: Busy Cursor or Progress Bar
          Jump_Over Level 5
          Use progress bar related to file.length (in bytes) and current position ( file.tell() as bytes offset).
          Example:
          // your code
          // ... your code
          var end = dirFile.length;
                    // Progress bar -----------------------------------------------------------------------------------
                    var
                              progressWin = new Window ("window", "Export XML"),
                              progressBar = progressWin.add ("progressbar", [12, 12, 450, 36], 0, end);
                    progressWin.show();
          do {
          // your code
                              progressBar.value = dirFile.tell();
          while (dirFile.eof == false);
                    progressWin.close();
                    dirFile.close()
          Jarek
          • 2. Re: Busy Cursor or Progress Bar
            jason_clement Level 1
            Thank you Jarek! Below is my final script (just the parts that were changed). Jason
                      // Progress bar
                      progressbar ("Importing file",end);
                      // Progress bar
                        do{
            //~             progressWin.close();
                        dirFile.close();
            function progressbar(title,max) {
                var w = new Window ("dialog", title, undefined, {closeButton: false});
                w.add ("progressbar", undefined, 0, max);
                var found = new Array (max);
                w.pbar = w.add ('progressbar', undefined, 0, found.length);
                w.show();
                for (var i = 0; i < found.length; i++){
                    w.pbar.value = i+1;
                    $.sleep(1);
