6 Replies Latest reply on Feb 7, 2014 5:38 PM by artfake
      • 1. Re: loop sound run by script
        elainecc Adobe Employee
        Hi, M-
        Sure.  You can use the snippets to find the code for "play audio from" in the actions pop-up from a trigger or any event handler.  Then, just replace the my_audio_element text with your element name.
        Hope that helps,
        -Elaine
        • 2. Re: loop sound run by script
          artfake Level 1
          Dear Elaine,
          thank you for your replay. But this answer not help me.
          I need to run plaing sound not once, but on repeat.
          "Play Audio From" run only once playing((
          M
          • 3. Re: loop sound run by script
            resdesign Adobe Community Professional & MVP
            You need to select your sound in the elements panel and check LOOP on the left panel.
            or in script:
            loop = true;
            • 4. Re: loop sound run by script
              jbowden Adobe Employee
              To loop using code, you'd write something like this:
              sym.$("my_audio_element")[0].loop = true;
              Or as resdesign mentions, you can click the Loop checkbox in the audio element properties.
              The loop property is a Boolean (either you loop endlessly or not at all), so you can't loop x number of times using the same code. To do a finite number of loops, you'd write a loop manually, using play and currentTime and tracking the number of loops until it's done.
              hth,
              Joe
              • 5. Re: loop sound run by script
                That is, exactly as Joe wrote the whole line for your sound.
                Note:
                If you choose autoplay off,  and check loop you can start your sound with an event and here also you can use the snippet of code you can use.
                For example a click event:
                var btnFX = sym.$("btnFX")[0];
                var music = sym.$("music")[0];
                // set up the music toggle for both sounds
                sym.$('musicBtn').click(function(){
                          if (music.paused) {
                                    music.play();
                                    btnFX.play();
                                    sym.getSymbol('musicBtn').stop('on');
                          } else {
                                    music.pause();
                                    btnFX.pause();
                                    sym.getSymbol('musicBtn').stop('off');
                • 6. Re: loop sound run by script
                  artfake Level 1
                  thank you, Joe.
                  it's works!
