3 Replies Latest reply on Feb 11, 2014 11:22 AM by NoPrevaricator
    Trapping cursor coordinates in Javascript
    JADarnell
      Hello Everyone:
         I am attempting to trap cursor coordinates but I do not know how to make that happen.  Here is the short algorithm I hope to implement:
      click object to select.
      click new location for object to move to
      move object to new location.
      I think I know how to do the first, but I have no idea how to make Javascript report the coordinates of the mouse cursor when I click on the new location.
      Please share with me any thoughts/documentation/snippets that might help.  I will greatly appreciate it.
      TIA.
      John
        • 1. Re: Trapping cursor coordinates in Javascript
          @John – if you are using InDesign CS5 (or above) I have something for you.
          At least a proof of concept that will work. Tested with InDesign CS5.5.
          The script will not read out any cursor coordinates.
          Unfortunately we cannot do this…
          Instead I am using:
          one event listener,
          an JPEG image already placed,
          the placeGun
          and the "afterSelectionChanged" event.
          To test the script below, you need:
          1.A The ESTK open, run the script from that
          OR:
          1.B Run the script with a keyboard shortcut from InDesign's Scripts Panel
          2. An open document
          3. An already placed JPEG image in the document (with a link status OK)
          4. One single page item selected (no text selected, not more than one object selected)
          This is just a proof of concept!
          I did not consider moving a selection greater than one object, I needed at least ONE image placed in the document, I did not consider double sided spreads with a coordiante system set by page.
          And: I really had fun writing this!
          Here the script (ExtendScript/JavaScript):
          //MoveSelectionTo_POSITION-OF-CURSOR_ProofOfConcept.jsx
          //Uwe Laubender
          //DESCRIPTION:Just a proof of concept. Some pieces missing!
          #targetengine "MovePositionToCursor[Proof Of Concept ONLY]"
          app.scriptPreferences.userInteractionLevel = UserInteractionLevels.interactWithAll;
          //SOME CHECKS:
          if(parseFloat(app.version)<7){alert("Does not run in InDesign v. "+app.version);exit()};
          if(app.documents.length == 0){alert("No document open!");exit()};
          if(app.selection.length !== 1 && !app.selection[0].hasOwnProperty("baselineShift")){
              alert("This is a proof of concept! Does ONLY work with ONE page item selected. NOT TEXT!");
              exit();
          if(app.documents[0].allGraphics.length == 0){
              alert("This is a proof of concept! Does ONLY work with AT LEAST ONE JPEG ALREADY placed!");
              exit();
          moveSelection();
          function moveSelection(){
          var myDoc = app.documents[0];
          var myOriginalSel = app.selection[0];
          var myOriginalSelID = myOriginalSel.id;
          for(var n=0;n<myDoc.links.length;n++){
              if(myDoc.links[n].status == LinkStatus.NORMAL && myDoc.links[n].linkType == "JPEG"){
                  var myImage = File(myDoc.links[n].filePath);
                  break;
          if(myImage){myDoc.placeGuns.loadPlaceGun(myImage)}
          else{
              exit();
          app.addEventListener("afterSelectionChanged", doSomething);
          app.select(app.documents[0].pageItems.itemByID(myOriginalSelID));
          function doSomething(myEvent){
              try{
              app.removeEventListener("afterSelectionChanged", doSomething);
              var myNewID = app.selection[0].id;
              var myGeoBounds = app.selection[0].getElements()[0].geometricBounds;
              app.documents[0].pageItems.itemByID(myNewID).remove();
              app.documents[0].pageItems.itemByID(myOriginalSelID).move([myGeoBounds[1],myGeoBounds[0]]);
              }catch(e){};
          Uwe
          • 2. Re: Trapping cursor coordinates in Javascript
            Oh. I forgot something ;-)
            To move the selection, the user has to click the cursor after executing the script.
            Uwe
            • 3. Re: Trapping cursor coordinates in Javascript
              NoPrevaricator
              Uwe:
                 Unfortunately, your suggested process even in its seminal stage was not something I could use.  However, your thought process did spawn a thought process that led to an eventual solution that ultimately did what I was looking for.  So I still owe you loads of thanks and if you are ever in Brookfield Missouri, I promise to take you to lunch.  We have a number of fine eating establishments in the area, such as McDonalds, Sonic (clone of McDonalds) and Pizza Hut. I promise you they are fastidiously clean, though they are a little unimaginative on the menu side (grin).
                 Take care and thanks for your input.
              R,
              John
