1 Reply Latest reply on Feb 7, 2014 11:31 PM by Nipun Asthana
    Preview is different than final compile? HELP PLEASE
    WZaD
      This is a simple test animation, but 2 things go wrong when I compile it
      1: the clouds in the compiled version move at different speeds than when I hit "play" in the workstation
      2: one of the clouds dissapears (the bottom one), and then reappears randomly, something that it doesn't do in the workstation
      Ive tried it in different layers, with different types of objects, and even capturing it frame-by-frame, but it always messes up when i export it!
      Heres the .fla and the .swf files, if someone could look and see if i'm overlooking something and give me feedbac
      http://speedy.sh/fxWTk/RECOVER-RECOVER-1.fla
        • 1. Re: Preview is different than final compile? HELP PLEASE
          Nipun Asthana Adobe Employee
          It looks like you have accidently added the same motion tween twice at different levels of nesting within the same symbol. Also within nesting, you're using Movieclip instance somewhere and Graphic instance at other places.
          This answers both of your queries:
          1. Speed is different because the resultant speed is the addition of two motions along the same path. (When previewing within application, animations within a movieclip are not shown but within Graphics are shown.)
          2. The disappearance happens due to the same eason. The start and end point of a grapic animation is dependent on the parent timeline and remains the same during looping. Movieclip animations on the other hand, always play completely and may spill over multiple loops. So basically the start point of the animation is getting shifted with every loop.
          You can remove one of the tweens from the nested symbol to fix this.
          -Nipun
