2 Replies Latest reply on Feb 10, 2014 3:16 PM by kdeuler
    Can't find satisfactory post on starting 2nd+ procedures in the same topic at step "1"...
    kdeuler Level 1
      All-
      Can anyone recommend the correct use of Paragraph and/or list styles to achieve the following in a RH topic?
      Procedure X
      1) Step one of procedure x
      2) Step two of procedure x
      3) Step three of procedure x
      Procedure Y
      1) Step one of procedure y
      2) Step two of procedure y
      3) Step three of procedure y
      When using Paragraph sty.es set with autonumbering, I get this (note that the continuation of step numbering in Procedure Y...)
      Procedure X
      Procedure Y
      4) Step one of procedure y
      5) Step two of procedure y
      6) Step three of procedure y
      I'm looking for the ability to both continue numbering after inserting a non-numbered item (such as code sample or graphic, etc.) This appears to be the default behavior. AND, I want to be able to start separate procedures within the same topic at step 1.
      Postings on this subject on this formum seem inconclusive. Case in point:
      http://forums.adobe.com/message/3720120#3720120
      I used to the way unstructured Framemaker paragraph styles work, where you have an inititial paragraph style with numbering 1 (or a), for example, and subsequent steps use a style that adds 1 to the number of the prevous step style. But, there doesn't appear to be such a feature in RH? Please advise how you've created the numbering in multiple procedures in the same doc.
      Thanks in advance.
      -Kurt
