10 Replies Latest reply on Feb 12, 2014 8:50 AM by magnum_jim
    PrE 12 Styles Not Working
    magnum_jim Level 1
      I have premier Elements 12, using a windows 7 pro. My Styles have stopped showing. they were visible under the drop down tag, suddenly they are gone. Any suggestions?
      They are not showing up in either mode.
      [Title was changed to reflect the problem - Hunt]
        • 1. Re: Jim WOD
          A.T. Romano Level 7
          magnum_jim
          Do you get the same results if you start a new project? Do you remember doing any particular maneuvers in the workspace immediately before the problem set in - saving Styles, creating Styles, etc? With the program closed, have you gone to the Styles Folder and deleted it and opened a new project?
          Libraries
          Documents
          Adobe
          Premiere Elements
          12.0
          and in the 12.0 Folder is the Styles Folder tha you delete.
          Based on that description
          Delete the Premiere Elements 12 Adobe Premiere Elements Prefs file
          Local Disk C
          Users
          Owner
          AppData
          Roaming
          Premiere Elements
          12.0
          and in the 12.0 Folder is the Adobe Premiere Elements Prefs file that you delete. Be sure to be working with Folder Option Show Hidden Files, Folders, and Drives active so that you can see the complete path. In this instance, not holding out hopes for this, but it is worth a try before the next step which should resolve the problem.
          Sign Out of the program in an opened project, Help Menu/Sign Out (the Deactivation step)
          Then uninstall the program via the typical Control Panel/Installed Programs route
          Do a computer run through of the ccleaner (regular cleaning and registry cleaning parts)
          http://www.piriform.com/ccleaner
          Reinstall the program with the antivirus and firewalls turned Off.
          Please review and the let us know the outcome so that you can consider what next if necessary.
          Thank you.
          ATR
          • 2. Re: PrE 12 Styles Not Working
            magnum_jim Level 1
            Hi A.T:
            I did all, including the uninstall. I then run the cleaner, plus
            defraged the disk.I then open the program that I was working on, and the
            style was again not visible. I then tried creating a new program.:-(
            Still there is no styles visible when I try to load a text . There are
            white text only. The styles are not there. Any ideas?
            Thank Jim Inman
                  Re: Jim WOD
            created by A.T. Romano <http://forums.adobe.com/people/A.T.+Romano> in
            /Premiere Elements/ - View the full discussion
            <http://forums.adobe.com/message/6107832#6107832
            • 3. Re: PrE 12 Styles Not Working
              A.T. Romano Level 7
              magnum_jim
              Thanks for the reply.
              Please confirm that you have done the following requested troubleshooting
              With the program closed, please go to Libraries/Documents/Premiere Elements/12.0/Styles. In the Styles folder disable the "workingset.prsl" file by changing its name from workingset.prsl to workingset.prslOLD. Then reopen the saved closed project or start a new project.
              In the prior post, I suggested a variation on this when I asked you to delete the whole Styles Folder.
              Please try let us know the results from renaming the workingset.prsl
              If that does not resolve the issue, then...
              If you have not already, let us check to see if the Styles thumbnails are on the computer hard drive
              Local Disk C
              Program Files
              Adobe
              Adobe Premiere Elements 12
              Presets
              Styles
              Common
              Thumbnails
              Next
              Libraries
              Documents
              Adobe
              Premiere Elements
              12.0
              Styles
              in the Styles Folder do you find a tempworkingset.prsl file and a workingset.prsl file?
              Looking forward to your results. Thanks again for the follow ups.
              ATR
              • 4. Re: PrE 12 Styles Not Working
                magnum_jim Level 1
                Thanks so very much, I appreciate your help. It is now, ok.
                Thanks again and please have a great day.
                Jim Inman
                      e: Jim WOD
                • 5. Re: PrE 12 Styles Not Working
                  A.T. Romano Level 7
                  magnum_jim
                  Great news. Great job.
                  Was it the renaming of the workingset.prsl file that did the job.
                  Thanks for the follow ups.
                  Continued success.
                  ATR
                  • 6. Re: PrE 12 Styles Not Working
                    magnum_jim Level 1
                    yes, renaming the file did it.
                    Thanks Again
                    • 7. Re: PrE 12 Styles Not Working
                      A.T. Romano Level 7
                      magnum_jim
                      Thanks, that is good information.
                      Your follow up is appreciated.
                      ATR
                      • 8. Re: PrE 12 Styles Not Working
                        magnum_jim Level 1
                        Just for your personal info, that same thing happened to me with
                        elements 11. I was never able to get it fixed.
                        1. I have a couple of question for you, do you work for Adobe?
                        2. If I have a question, can I email you, or should I post it?
                        3. Do you think I can handle the pro version, how different is the pro
                        version. I would only buy the program itself, and not the monthly update.
                        I would appreciate your reply.
                        Again, you were very helpful
                        Thank Jim
                        <http://forums.adobe.com/message/6111533#6111533
                        • 9. Re: PrE 12 Styles Not Working
                          A.T. Romano Level 7
                          magnum_jim
                          Thanks for the post.
                          My reply: I am not affiliated with Adobe in anyway. Just a Premiere Elements users with an overactive troubleshooting gene.
                          My reply. Posting questions in the Premiere Elements Forum is preferred since then we all learn in the learning and sharing process. But, I do read and reply to all my private messages here.
                          My reply. There are several new and advanced features in Premiere Pro, but with a good Premiere Elements base, the transition between programs should not be all that difficult. However the deal breaker seems to be purchased product versus subscriptions. As I understand it, Premiere Pro CS6 goes through as CC on the subscription basis only. So far, Premiere Elements has not been "under the CC" and subcription purchase. However, I discovered that, for version 12, Adobe is selling direct only the download and not the boxed packaging. But, its authorized resellers are selling the boxed packaging.
                          Please let us know if you need clarification on any of the above.
                          Thanks.
                          ATR
                          • 10. Re: PrE 12 Styles Not Working
                            magnum_jim Level 1
                            I might try the premier pro. I guess I need to take time.
                            Thanks Again
                            <http://forums.adobe.com/message/6113652#6113652
