0 Replies Latest reply on Jun 15, 2006 9:07 AM by maddict
    GetVariable() doesn't work in FireFox for object member variables
      I'm trying to access Flash member variables from Javascript using GetVariable. The following line of code works for IE but not for Firefox:
      var variable = swf.GetVariable("someObject.someProperty");
      In IE, the GetVariable() function returns the correct value for the property. However in Firefox, the GetVariable() function returns "null" when trying to access the property. If I just try to access the object in Firefox (i.e. swf.GetVariable("someObject"), I get a string back (instead of the object that I am expecting). If I try to access a variable (such as a string) and not an object using GetVariable(), this works in both Firefox and IE.
      Any ideas what I am doing wrong? I suspect that my syntax for accessing object member variables in Firefox is incorrect but I have not been able to find any documentation on the correct syntax.
      Any assistance would be greatly appreciated.
