4 Replies Latest reply on Feb 12, 2014 3:18 AM by David_Powers
    Unordered list displayed horizontally
    Aspnet
      Hello,
      I am really new to Dreamweaver and I tried to complete (succesfully) the video on how to build my first website.
      Following the instruction was not so complicate...
      I tried to do pretty much alone the same focusing in creating the button from an unordered list
      I did with no CSS file, I created a new one empty. I am able to remove the bullet point, align the list but I can not display the button horizontally and I do not understand why.
      This is what I did:
      • create a Navigation  (id= buttons)
      • create an unordered list
      • create a CSS file empty
      • add a selection #buttons ul where I deleted bullet point and aligned the list
      • add a selection #buttons a
        • here I have problems. I apply with 25% (4 buttons) and set the float option to the left but the list remains vertical
      What I do wrong???? It seems I am doing like in the video. Is maybe related to the CSS file? Is not correct doing that with an empty one?
      Thanks for any help
        • 1. Re: Unordered list displayed horizontally
          David_Powers Level 7
          Without seeing your code, it's difficult to say what might have gone wrong. Here's a very simple example of four items in an unordered list floating horizontally. In the HTML:
          <ul id="buttons">
              <li><a href="#">Home</a></li>
              <li><a href="#">Products</a></li>
              <li><a href="#">Services</a></li>
              <li><a href="#">Contact</a></li>
          </ul>
          In the style sheet:
          #buttons  {
              list-style-type: none;
              margin: 0px;
              padding: 0px;
          #buttons a {
              display: block;
              width: 25%;
              float: left;
          • 2. Re: Unordered list displayed horizontally
            Aspnet Level 1
            Hello, thanks for your answer. Of course it is working, but still I do not get why is not working mine.
            here it is the html
            <!doctype html>
            <html>
            <head>
            <meta charset="UTF-8">
            <title>Home</title>
            <link href="styles/main copy 2.css" rel="stylesheet" type="text/css">
            </head>
            <body>
            <nav id="navbar">
              <ul>
                <li>Home</li>
                <li>Products</li>
                <li>Services</li>
                <li>Contacts</li>
              </ul>
            </nav>
            </body>
            </html>
            and here the CSS
            #navbar ul {
                      margin-top: 0px;
                      margin-right: 0px;
                      margin-bottom: 0px;
                      margin-left: 0px;
                      padding-top: 0px;
                      padding-right: 0px;
                      padding-bottom: 0px;
                      padding-left: 0px;
            #navbar a {
                      width: 25%;
                      display: block;
                      float: left;
            • 3. Re: Unordered list displayed horizontally
              Aspnet Level 1
              Hello,
              I find the mistake. I just post it the solution in case somebody else is stuck at same point trying to do it alone.
              "#id a" refers to a link so before assign a css to alink I had to transform the unordered list to a link a href="#"
              After that it works
              • 4. Re: Unordered list displayed horizontally
                Congratulations on finding the answer yourself. Making mistakes can be painful, but it's often a good way of learning.
                You might find the following tutorial helps you understand CSS selectors better: http://www.adobe.com/devnet/dreamweaver/articles/css-selectors-pt1.html.
