1 Reply Latest reply on Feb 12, 2014 4:26 AM by Peter Spier
    keyboard shortcuts
    christianwill
      How can you cancel keyboard shortcut commands
        • 1. Re: keyboard shortcuts
          Edit > Keyboard Shortcuts... Make a custom set based on the default set if you are not already using a custom set, find the command for which you want to remove the existing shortcut, and delete the current shortcut. You can change or add new ones here, too.
