3 Replies Latest reply on Feb 12, 2014 7:42 AM by Trevorׅ
    Change the characterstyle in all textframes
    Alexan.K
      Hello all,
      i have a problem in my javascript script. I want a script that check all textframes in the document and it have to check the characterstyle from each char.
      If there is a "-" in the text, the characterstyle will switch to normal. The problem is that i did not find the text in the textframe with the javascript. I´m new in the business.
      I think my approach is wrong, but i can´t find an another one.
      My code :
      var doc = app.activeDocument;
      var tf = doc.textFrames.anyItem();
      var paras = tf.paragraphs.everyItem().getElements();
      var applied_style = doc.characterStyles.itemByName('Cent');
      var paras_with_style = [];
      for (var i=0,l=paras.length; i<l; i++) {
         var para = paras[i];
         if (para.appliedCharacterStyle == applied_style) {
            var contenttext = para.contents;
                  if (contenttext == "-") {
                          para.changeTextPreferences.position = Position.normal;
        else {
                          para.changeTextPreferences.position = Position.superscript;
      Thanks for your help
      Greets Alex
