2 Replies Latest reply on Feb 13, 2014 3:11 AM by adobefishman
    After Effects alphabetical order is a bit wonky
    adobefishman Level 1
      If I create comps that are numbered:
      001
      002
      003
      004
      No problem.
      But AE seems to insist on sorting my comps this way if I modify the names.
      001
      002
      003
      004
      001a
      or...
      001
      002
      003
      004
      001-alt
      In any other app or in my Finder this is not the case.
      Other apps or the Finder display the list as follows:
      001
      001a
      002
      003
      004
      or...
      001
      001-alt
      002
      003
      004
      Kind of drives me crazy as I usually modify my alternate sequences with an extra alpha character (1001a,001b,001c...). I've been doing it this way for decades. The only app that gives me grief is AE. Makes no sense...no sense I can see!
        • 1. Re: After Effects alphabetical order is a bit wonky
          It makes sense in that AE first sorts by numbers, no matter what. AE doesn't care for human-readable ordering, but you are right, it would probably be a sensible option. In any case, your system could probably be easily fixed by switching to an a,b,c naming pattern. I had an article on that on my deceased error code database. Problem with your approach is that it is always going to end up confusing because you may actually at one point introduce dates, version numbers or other numerals in teh file/ folder names themselves and if you accidentally forget a space or underscore, it could completely jumble up your ordering no matter whether AE were smarter about it...
          Mylenium
          • 2. Re: After Effects alphabetical order is a bit wonky
            Appreciate what you are saying.
            But, as I said, I've been using my system for decades without it confusing me.
            So no worries there.
            And introducing spaces or dates in my system should affect it alpha-numerically just like I would expect in other apps
            But in AE it does not.
            001
            002
            003
            004
            001-alternate
            If I had a comp with a wild set of numbers.
            i.e. 7645231
            and f I added a letter onto the end it shouldn't send it shooting to the bottom of a list.
            But it does.
            But my system for organizing isn’t the fundamental issue.
            The sorting order seems like a grave error in alpha-numeric ordering.
            The equivalent in sorting in my system is:
            AAA
            AAA1
            BBB
            CCC
            DDD
            AE has no problem.
            But if Adobe sorted like this:
            AAA
            BBB
            CCC
            DDD
            AAA1
            Wouldn’t that seem odd?
            And if Adobe were consistent, I’d be less surprised.
            While Encore sorts like After Effects,
            Photoshop, Audition and Media Encoder sort the way I would expect they should.
            Perhaps most importantly it isn’t even consistent within AE itself. If I have numbered files that have extensions they sort as I would expect, but numbered Compositions do not (!). What is up with that!?!?
            The fact that numbers don’t sort in numeric-alpha order seems…  well…  just... wrong.
