• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Firefox issue
Explorer ,
Jun 15, 2006 Jun 15, 2006
I got a file browse in my project.
<input type="file" name="frm_file" value="" size="100">
When i open project in firefox, filename only inserted in db.
In IE, path and filename are inserted to db.
Why "input type="file" " is working different in firefox?. What is solution to fix this problem?.
TOPICS
Advanced techniques
Views
336
Translate
Translate
Report
Report
Community guidelines
community guidelines
Advocate ,
Are you doing a <cffile action="upload"...> anywhere between when the user submits that form and before your database insert?
Votes
Translate
Translate
Report
Report
Explorer ,
No.
I just need user selected path and filename. No need to upload file.
I am using this code.
in insert query, i use frm_file to insert path and filename.
In IE, filename and pathname is inserted to db.
In firefox, filename is inserted, path is missing. How to get path in firefox?
Votes
Translate
Translate
Report
Report
Advocate ,
If you don't need them to upload the file, then don't use a file input type. That's the whole point of a file input type.
Votes
Translate
Translate
Report
Report
Explorer ,
Users want to browse and pick the file name. How will i give a browse feature, if i am not using input=file?.
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
You are dealing with a security 'sand box' issue. FF correctly keeps from the server the exact location of the file on the users hard drive, since the theory is that this information can be used to 'hack' the users computer in the future. IE is using an 'unsafe' method.
Kronin555 is correct. The only good use for the type="file" is in conjuction with upload code. I am sure you will find that the other browsers all pass dis-similar information from that field, as they all have different concepts of security.
Votes
Translate
Translate
Report
Report
Resources
Documentation
