4 Replies Latest reply on Feb 13, 2014 7:12 AM by the_wine_snob
    Help getting AVI files into PE12
    EHogger
      I have AVI videos from some cheap Hitachi HD cameras which won't load in PE12. The files load as just audio, but play back fine on the computer.
      I've read the various threads on similar issues but haven't found a good work around yet.
      GSpot shows the codec as H.264/MPEG-4 AVC.
      I have tried using FFMpeg to rewrap the files as mp4 as shown in this thread: http://forums.adobe.com/thread/854115 , but I just get an unsupported codec error when I import the mp4s.
      I've found that installing k-lite codec pack lets the video play, but the playback goes jerky after a few seconds.
      I copied the reports from GSpot and MediaInfo. I really want to find a way to get these working without doing full conversions of all the files each time, since this has damaged the quality in the past. If conversion is the only option, can anyone suggest exactly how to convert these files without losing any quality?
      Many thanks to anyone who can help.
      General
      Count                                    : 285
      Count of stream of this kind             : 1
      Kind of stream                           : General
      Stream identifier                        : 0
      Inform                                   : AVI: 15.1 MiB, 11s 712ms
      Count of video streams                   : 1
      Count of audio streams                   : 1
      Video_Format_List                        : AVC
      Video_Format_WithHint_List               : AVC
      Codecs Video                             : AVC
      Audio_Format_List                        : ADPCM
      Audio_Format_WithHint_List               : ADPCM (Intel)
      Audio codecs                             : ADPCM
      Complete name                            : \\marge\Users\Sixth Form\Upper\April.Gunn\My Documents\My Videos\026.AVI
      Folder name                              : \\marge\Users\Sixth Form\Upper\April.Gunn\My Documents\My Videos
      File name                                : 026
      File extension                           : AVI
      Format                                   : AVI
      Format                                   : AVI
      Format/Info                              : Audio Video Interleave
      Format/Extensions usually used           : avi
      Commercial name                          : AVI
      Internet media type                      : video/vnd.avi
      Interleaved                              : Yes
      Codec                                    : AVI
      Codec                                    : AVI
      Codec/Info                               : Audio Video Interleave
      Codec/Extensions usually used            : avi
      File size                                : 15823980
      File size                                : 15.1 MiB
      File size                                : 15 MiB
      File size                                : 15 MiB
      File size                                : 15.09 MiB
      Duration                                 : 11712
      Duration                                 : 11s 712ms
      Duration                                 : 00:00:11.712
      Overall bit rate mode                    : VBR
      Overall bit rate mode                    : Variable
      Overall bit rate                         : 10808730
      Overall bit rate                         : 10.8 Mbps
      Stream size                              : 37760
      Stream size                              : 36.9 KiB (0%)
      Stream size                              : 37 KiB
      Stream size                              : 36.88 KiB
      Proportion of this stream                : 0.00239
      Recorded date                            : 2004-03-04
      File creation date                       : UTC 2004-03-04 20:19:40.000
      File creation date (local)               : 2004-03-04 20:19:40.000
      File last modification date              : UTC 2004-03-04 20:19:40.000
      File last modification date (local)      : 2004-03-04 20:19:40.000
      Writing library                          : AMBA
      ICRT                                     : 20:19:39
      Video
      Count                                    : 272
      Kind of stream                           : Video
      StreamOrder                              : 0
      Inform                                   : 10.4 Mbps, 1920*1080 (16:9), at 29.970 fps, AVC (Main@L4.0) (CABAC / 4 Ref Frames)
      Format                                   : AVC
      Format/Info                              : Advanced Video Codec
      Format/Url                               : http://developers.videolan.org/x264.html
      Commercial name                          : AVC
      Format profile                           : Main@L4.0
      Format settings                          : CABAC / 4 Ref Frames
      Format settings, CABAC                   : Yes
      Format settings, ReFrames                : 4
      Format settings, ReFrames                : 4 frames
      Format settings, GOP                     : M=1, N=4
      Internet media type                      : video/H264
      Codec ID                                 : H264
      Codec                                    : H264
      Codec                                    : AVC
      Codec/Family                             : AVC
      Codec/Info                               : Intel H.264
      Codec/CC                                 : H264
      Codec profile                            : Main@L4.0
      Codec settings                           : CABAC / 4 Ref Frames
      Codec settings, CABAC                    : Yes
      Codec_Settings_RefFrames                 : 4
      Duration                                 : 11712
      Bit rate mode                            : VBR
      Bit rate mode                            : Variable
      Bit rate                                 : 10401036
      Bit rate                                 : 10.4 Mbps
      Maximum bit rate                         : 12375040
      Maximum bit rate                         : 12.4 Mbps
      Width                                    : 1920
      Width                                    : 1 920 pixels
      Height                                   : 1080
      Height                                   : 1 080 pixels
      Pixel aspect ratio                       : 1.000
      Display aspect ratio                     : 1.778
      Display aspect ratio                     : 16:9
      Frame rate                               : 29.970
      Frame rate                               : 29.970 fps
      Frame count                              : 351
      Resolution                               : 8
      Resolution                               : 8 bits
      Colorimetry                              : 4:2:0
      Color space                              : YUV
      Chroma subsampling                       : 4:2:0
      Bit depth                                : 8
      Bit depth                                : 8 bits
      Scan type                                : Progressive
      Interlacement                            : PPF
      Interlacement                            : Progressive
      Bits/(Pixel*Frame)                       : 0.167
      Stream size                              : 15227116
      Stream size                              : 14.5 MiB (96%)
      Stream size                              : 15 MiB
      Stream size                              : 14.52 MiB
      Proportion of this stream                : 0.96228
      Buffer size                              : 12375040 / 12375040
      Audio
      Count                                    : 222
      Kind of stream                           : Audio
      Inform                                   : 384 Kbps, 48.0 KHz, 4 bits, 2 channels, ADPCM (Intel)
      Format                                   : ADPCM
      Commercial name                          : ADPCM
      Codec ID                                 : 11
      Codec ID/Hint                            : Intel
      Codec                                    : 11
      Codec                                    : ADPCM
      Codec/Family                             : ADPCM
      Codec/Info                               : Intel ADPCM
      Codec/CC                                 : 11
      Duration                                 : 11608
      Duration                                 : 11s 608ms
      Duration                                 : 00:00:11.608
      Bit rate mode                            : CBR
      Bit rate mode                            : Constant
      Bit rate                                 : 384000
      Bit rate                                 : 384 Kbps
      Channel(s)                               : 2
      Channel(s)                               : 2 channels
      Sampling rate                            : 48000
      Sampling rate                            : 48.0 KHz
      Samples count                            : 557184
      Resolution                               : 4
      Resolution                               : 4 bits
      Bit depth                                : 4
      Bit depth                                : 4 bits
      Stream size                              : 559104
      Stream size                              : 546 KiB (4%)
      Stream size                              : 546.0 KiB
      Proportion of this stream                : 0.03533
      Interleave, duration                     : 1.29
      Interleave, duration                     : 43
      Interleave, duration                     : 43 ms (1.29 video frame)
        • 1. Re: Help getting AVI files into PE12
          You're not going to be able to use an MP4 codec AVI in Premiere Elements 12, and your convertor may not be converting it to a usable format.
          The best solution is to load this video file into Windows Movie Maker Live and then output it from there as a 1920x1080 MP4. THIS MP4 will work in Premiere Elements 12 (if you have the latest version of Quicktime installed).
          • 2. Re: Help getting AVI files into PE12
            nealeh Level 5
            I had that problem with my cheap Hitachi camcorder. Adobe recommended installing FFDshow which, as I recall, worked. I think the reason was that PRE does not have a native DirectShow filter built in.
            Cheers,
            Neale
            If this post or another user's post resolves the original issue, please mark the posts as correct and/or helpful accordingly. This helps other users with similar trouble get answers to their questions quicker. Thanks.
            • 3. Re: Help getting AVI files into PE12
              EHogger Level 1
              That would explain why K-Lite sort of worked. Thanks for the advice. I'll try it
              • 4. Re: Help getting AVI files into PE12
                the_wine_snob Level 9
                EHogger,
                As has been pointed out, the H.264 AVCHD CODEC, inside the AVI wrapper is non-standard, but some camera mfgrs. insist on doing that. The problem is that Premiere (either flavor) is not coded to look for H.264 inside an AVI. While AVI can contain a lot of different CODEC's, having H.264 inside is not what most programs expect.
                Hope that Neale's suggetion works for you.
                As far as editing ANY H.264 material, the main apect of a computer, that will come into play is the CPU. An underpowered computer will have issues playing it smoothly, as it takes a lot of CPU cycles to work with that material, under good circumstances. In the provided information, I did not see the specs. of your computer, but if the CPU is less than a very fast i5, playback performance may weill suffer.
