6 Replies Latest reply on Aug 9, 2006 7:17 PM by Craig Grummitt
    better way
    Caurj
      which is a better way (smaller) to write this:
      if (p1 == 1) {res1 = "RIGHT";}
      else {res1 = "WRONG";}
      if (p2 == 1) {res2 = "RIGHT";}
      else {res2 = "WRONG";}
      (this will repeat till p10==1)
      thanks
        • 1. Re: better way
          Level 7
          "Caurj" <webforumsuser@macromedia.com> wrote in message news:ebdajp$595$1@forums.macromedia.com...
          > thanks
          for (var a = 1; a<= 10; a ++)
          var r = eval("res" + a); // get a pointer to the res1 to res10 variable
          var p = eval("p" + a); // get a pointer to the p1 to p10 variable
          if ( p == 1 )
          r = "RIGHT";
          else
          r = "WRONG";
          That otta do it.
          tralfaz
          • 2. Re: better way
            Craig Grummitt Level 3
            correct me if i'm wrong tralfaz, but i believe you're copying the contents of res1 to res10 into r, rather than a pointer. (same with p)
            Caurj - apologies if i'm telling you about something you already know about, but you may want to have a look at Boolean variables.
            Try:
            for (var a = 1; a<=10; a++) {
            if (this["p"+a] == 1) {
            this["res"+a]= "RIGHT";
            } else {
            this["res"+a]= "WRONG";
            • 3. Re: better way
              Level 7
              "Craig Grummitt" <webforumsuser@macromedia.com> wrote in message news:ebdsft$q08$1@forums.macromedia.com...
              > Try:
              > } else {
              Both eval and this[ ] return pointers to objects. There isn't a bit of difference in the results. It's easy to test it. (why
              didn't you?)
              tralfaz
              • 4. Re: better way
                Level 7
                > didn't you?)
                > tralfaz
                Craig.. I'm sorry. I guess I made some changes to the code after I tested it trying to simplify things. I checked it again and I
                see that you are right. I've often used the eval() function to return pointers to objects but it's not working for variables. Your
                code is better. Thanks for pointing out my error.
                tralfaz
                • 5. Re: better way
                  tralfaz i think you've misunderstood my point. yes i agree that in essence eval and this will do the same thing here - that's just a personal preference to use 'this'. it's also true that they can return pointers to objects. however caurj is referring to variables, not objects, in which case they will return the contents of the variable.
                  to illustrate:
                  a="hello"
                  var b=eval("a"); // or var b=this["a"]
                  b="goodbye";
                  trace(a); //outputs "hello"
                  feel free to test it.
                  • 6. Re: better way
                    stop press - just caught your last post... ;) no worries i probably could have explained more thoroughly.
