1. Re: Web object interaction missing!
Lilybiri Feb 13, 2014 6:42 AM (in response to Sreekanth_S)With the exception of the Millionaire interaction, all interactions have disappeared for me as well. Will contact someone.
2. Re: Web object interaction missing!
Sreekanth_S Feb 13, 2014 6:45 AM (in response to Lilybiri)Oh, that has happened to me many times, say atleast once a week. I thought it happens to mortals like me. Didn't expect Captivate to ditch its best friends
Sreekanth
3. Re: Web object interaction missing!
Lilybiri Feb 13, 2014 6:53 AM (in response to Sreekanth_S)Do you want to say I'm not normal? Heard that too much in my life
BTW you can still insert an interaction with Insert, Widget. The widget panel works as well (you can change the path there), but will only show static interactions, not the interactive games. Very weird.
Lilybiri
4. Re: Web object interaction missing!
Sreekanth_S Feb 13, 2014 7:09 AM (in response to Lilybiri)Thanks for the tip, Lilybiri.
Sreekanth
5. Re: Web object interaction missing!
Sreekanth_S Feb 13, 2014 9:12 AM (in response to Sreekanth_S)Ok, the interaction is back home. It says "updated", but doesn't say anything about what got changed.
Sreekanth
6. Re: Web object interaction missing!
Lilybiri Feb 13, 2014 10:11 AM (in response to Sreekanth_S)Still don't see any interaction except Millionaire myself. Will have to use the widget workaround trick, problem is always having to look for that long path.
Lilybiri
