4 Replies Latest reply on Feb 17, 2014 7:13 AM by Pedro Cortez Marques
    Move a layer/layerset into a layerset using ID only
    oddgames Level 1
      I'm trying to move a layer into a layerset using it's ID (not name or index).
      This function below works if I use putName instead of putIdentifier, does anyone have some code that will move a layer into a layerset using only ID?
      I keep getting General photoshop error occurred.
           moveLayer : function( fromLayer, toLayer )
              var desc5 = new ActionDescriptor();
              var ref4 = new ActionReference();
              ref4.putIdentifier( charIDToTypeID('Lyr '), Number(fromLayer) );
              desc5.putReference( charIDToTypeID('null'), ref4 );
              var ref5 = new ActionReference();
              ref5.putIndex( charIDToTypeID('Lyr '), this.getLayerIndex(toLayer) );
              desc5.putReference( charIDToTypeID('T   '), ref5 );
              desc5.putBoolean( charIDToTypeID('Adjs'), false );
              desc5.putInteger( charIDToTypeID('Vrsn'), 5 );
              try
              executeAction( charIDToTypeID('move'), desc5, DialogModes.NO );
              catch(e)
                  alert(e);
          // Get layer index but return 0 if there is an error.
          getLayerIndex: function(id)
              var ref = new ActionReference();
              ref.putIdentifier( charIDToTypeID('Lyr '), id );
              try
                  activeDocument.backgroundLayer;
                  return executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1;
              catch(e)
                  try
                      return  executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ));
                   catch(e)
                       return 0;
        • 1. Re: Move a layer/layerset into a layerset using ID only
          Pedro Cortez Marques Level 3
          It is simpler using this?
          var thisLayer = activeDocument.activeLayer;
          // create new layerset if doesn't exist
          if (activeDocument.layerSets.length == 0) activeDocument.layerSets.add();
          // return to previous selected layer
          activeDocument.activeLayer = thisLayer;
          // move layer to the referenced layerSets[0] but the id of this element could be any number
          activeDocument.activeLayer.move (activeDocument.layerSets[0], ElementPlacement.PLACEATEND);
          So the solution is to create first a script for(var a in activeDocument.layerSets) to reference your chosen layerSet by id and if exists it gives you the index.
          • 2. Re: Move a layer/layerset into a layerset using ID only
            oddgames Level 1
            My extension has it's own "layer list" that represents only a hand ful of layers that have meta data that has been set by the extension.
            I need to be able to move exisiting layers into existing layer sets using their ID.
            Does this line of code place it within the layerset? Or after it?
            • 3. Re: Move a layer/layerset into a layerset using ID only
              oddgames Level 1
              This seems to work:
                   moveInside : function( fromLayerID, toLayerID )
                      var desc = new ActionDescriptor();
                      var sourceRef = new ActionReference();
                      sourceRef.putIdentifier( charIDToTypeID( "Lyr " ), fromLayerID );
                      desc.putReference( charIDToTypeID( "null" ), sourceRef );
                      var layerIndex = this.getLayerIndex(toLayerID);
                      var destinationRef = new ActionReference();
                      destinationRef.putIndex( charIDToTypeID( "Lyr " ), layerIndex-1 );
                      desc.putReference( charIDToTypeID( "T   " ), destinationRef );
                      desc.putBoolean( charIDToTypeID( "Adjs" ), false );
                      desc.putInteger( charIDToTypeID( "Vrsn" ), 5 );
                      executeAction( charIDToTypeID( "move" ), desc, DialogModes.NO );
                      try
                      catch(e)
                          try
                           catch(e)
                               return 0;
              • 4. Re: Move a layer/layerset into a layerset using ID only
                move(1st argument , 2nd argument)
                1st argument:
                the layerSet or another layer
                2nd argument:
                once layerSet has been set, this will set the layer in 1 of these 3 options:
                // there are 3 types of placement:
                ElementPlacement.PLACEAFTER // use this when using move() to place a layer after another layer
                ElementPlacement.PLACEBEFORE // use this when using move() to place a layer before another layer
                If you want to move layers inside a layerSet the logic os the same but using only layers.
