6 Replies Latest reply on Jul 4, 2006 11:37 PM by flynnc
    Problem with listener
    flynnc Level 1
      As a flash newbie I am trying use a listener to watch for a user selecting a specific text box and clearing the temporary message it is displaying. When I use the code attached below, both text boxes clear when the user clicks.
      Can anyone help with this???
      //set shared object
      var test_so:SharedObject = SharedObject.getLocal("test", "/");
      //create initial text boxes and populate with text
      this.createTextField("foreName",this.getNextHighestDepth(),300,225,450,40);
      foreName.border = true;
      foreName.text = "<< Please enter forename here >>";
      this.createTextField("surName",this.getNextHighestDepth(),300,288.4,450,40);
      surName.border = true;
      surName.text = "<< Please enter surname here >>";
      //set text format
      var txtFormat:TextFormat = new TextFormat();
      txtFormat.align = "center";
      txtFormat.bold = true;
      txtFormat.size = 18;
      txtFormat.color = 0x006600; // green
      foreName.setTextFormat(txtFormat);
      surName.setTextFormat(txtFormat);
      rankName.setTextFormat(txtFormat);
      unitName.setTextFormat(txtFormat);
      //set up listener object
      var oListener_1:Object = new Object ();
      oListener_1.onMouseUp = function (){
      oListener_1.onSetFocus("foreName");
      foreName.type = "input";
      foreName.text = ""
      Mouse.removeListener(oListener_1);
      // Handler for userName.onChanged
      foreName.onChanged = function(){
      test_so.data.fore = foreName.text;
      Mouse.addListener(oListener_1);
      var oListener_2:Object = new Object ();
      oListener_2.onMouseUp = function (){
      oListener_2.onSetFocus("surName");
      surName.type = "input";
      surName.text = ""
      Mouse.removeListener(oListener_2);
      // Handler for surName.onChanged
      surName.onChanged = function() {
      test_so.data.sur = surName.text;
      Mouse.addListener(oListener_2);
        • 1. Re: Problem with listener
          you don't need two listeners, you don't need to use an onSetFocus() handler and an onMouseUp handler and you shouldn't be using a string as any functions parameter. try:
          • 2. Re: Problem with listener
            ricklecoat
            Thanks for your reply Luigi.
            I thought it was a path problem too, and your response made perfect sense - -target the button inside the MC rather than the MC itself. But when I did that it still didn't work. So I decided to go the Occams Razor route and cut away all the extraneous items -- started with a fresh .fla. This new movie has only two frames, and one button -- a simple button this time, with no nesting of any sort.
            Frame one contains a stop command and the listener code for the button; the listener code tells the _root timeline to go to frame 2 and stop. Frame 2 contains a cloud shape, so I'll know easily if the button has worked or not.
            The button instance is called clicker_btn.
            The listener is called myListener.
            The button click still does not work, and I'm really pulling my hair out now.
            Here's the code that sits in Frame 1 of the new test file:
            Thanks.
            // Pause frame 1 until button clicked
            stop();
            // LISTENER
            var myListener:Object = new Object();
            myListener.click = function(evtObj) {
            gotoAndStop(2);
            clicker_btn.addEventListener("click", myListener);
            • 3. Re: Problem with listener
              ricklecoat Level 1
              Oops, I posted the above to the wrong thread. Still, it's about Listeners, so it's still faintly relevant. Apologies for the error.
              • 4. Re: Problem with listener
                flynnc Level 1
                Hi kglad,
                Thanks for your response to my problem.
                I tried the code you attached but for some reason when I select the text box the text remains. I don't know if I have something else missing from the code?
                Also I am using Flash 8 Professional.
                Cheers
                • 5. Re: Problem with listener
                  that should be:
                  • 6. Re: Problem with listener
                    flynnc Level 1
                    Thanks for the help and code kglad that works great.
                    Cheers
