3 Replies Latest reply on Feb 17, 2014 10:46 AM by sinious
    How to detect how much of an object has been “cleaned” ?
    aseel jaradat
      so when the player end clening simple animation start
      var lineSize:Number=40;
      var doDraw:Boolean=false;
      var resumeDrawing:Boolean=false;
      var erasableBitmapData:BitmapData = new BitmapData(600, 600, true, 0xFFFFFFFF);
      var erasableBitmap:Bitmap = new Bitmap(erasableBitmapData);
      erasableBitmap.cacheAsBitmap = true;
      addChild(erasableBitmap);
      Object(this).dirtyBook.cacheAsBitmap = true;
      Object(this).dirtyBook.mask = erasableBitmap;
      var eraserClip:Sprite = new Sprite();
      initEraser();
      function initEraser():void {
                eraserClip.graphics.lineStyle(lineSize,0xff0000);
                eraserClip.graphics.moveTo(stage.mouseX,stage.mouseY);
      var drawnBitmapData:BitmapData = new BitmapData(600, 600, true, 0x00000000);
      var drawnBitmap:Bitmap = new Bitmap(drawnBitmapData);
      stage.addEventListener(MouseEvent.MOUSE_MOVE,maskMove);
      stage.addEventListener(MouseEvent.ROLL_OUT, maskOut);
      stage.addEventListener(MouseEvent.ROLL_OVER,maskOver);
      stage.addEventListener(MouseEvent.MOUSE_DOWN,startDrawing);
      stage.addEventListener(MouseEvent.MOUSE_UP,stopDrawing);
      Mouse down handler
      Begin drawing
      function startDrawing(e:MouseEvent):void {
                doDraw=true;
      Mouse up handler
      Stop drawing
      function stopDrawing(e:MouseEvent):void {
                doDraw=false;
                resumeDrawing = false;
                trace("Sto00o0p");
      Mouse out handler
      If user was drawing when they moved mouse off stage, we will need
      to resume drawing when they move back onto stage.
      function maskOut(e:Event):void {
                if (doDraw){
                          resumeDrawing = true;
      Mouse over handler
      If user's mouse if still down, continue drawing from the point where
      the mouse re-entered the stage.
      function maskOver(e:MouseEvent):void {
                if (resumeDrawing){
      Mouse move handler
      function maskMove(e:MouseEvent):void {
                if (doDraw && !resumeDrawing){
                          // Draw a line to current mouse position
                          eraserClip.graphics.lineTo(stage.mouseX,stage.mouseY);
                          // Clear the drawn bitmap by filling it with a transparent color
                          drawnBitmapData.fillRect(drawnBitmapData.rect, 0x00000000);
                          // Copy our eraser drawing into the erasable bitmap
                          // (This is required to ensure the smooth alpha edges on our eraser are retained)
                          drawnBitmapData.draw(eraserClip , new Matrix(), null, BlendMode.NORMAL);
                          // Fill the erasable bitmap with a solid color
                          erasableBitmapData.fillRect(erasableBitmapData.rect, 0xFFFFFFFF);
                          // Copy the scribble bitmap to our main bitmap, with blendmode set to ERASE
                          // This erases the portion of the mask that has been drawn.
                          erasableBitmapData.draw(drawnBitmap, new Matrix(), null, BlendMode.ERASE);
                // Update after event to ensure no lag
                e.updateAfterEvent();
