0 Replies Latest reply on Feb 14, 2014 8:34 AM by s.vnesh
    Data merge crash in ID CS6 server (but works in ID CS6 desktop)
      I have a strange problem with datamerge solution of InDesign cs6 server.
      There is a 20-page indd document and a 50-record csv file to be used along with it.
      Creating merged document (using data merge) causes ID CS6 server to crash right after the moment the following line executes:
      However, strangely, for the same template file there is no crash in InDesign desktop counterpart.
      I certainly seems that there is some inherent problem with data merge in the InDesign server. All data merge settings are same for both applications.
      Even there is no crash if I directly export to PDF as follows:
      objDoc.dataMergeProperties.exportFile(ExportFormat.PDF_TYPE, outputfile);
      So, in summary for the same template file:
      objDoc.mergeRecords(); // crash occurs in InDesign server but not in desktop counterpart
      objDoc.dataMergeProperties.exportFile(...); // no crash at all
      It would be a great help if someone can throw some light on this.
