8 Replies Latest reply on Feb 17, 2014 11:40 AM by bkdzlamp
    Loss of quality when using "Replace with Adobe After Effects Composition"
    bkdzlamp
      My workflow:
      [1] Create new Premiere sequence with raw screen capture footage (h.264 mov 12fps ~2mbps)
      [2] Use blade tool to cut footage in a section that needs effects
      [3] Right click on section and choose "Replace with Adobe After Effects Composion"
      *For the purpose of this test, that is all I did (no effects add in either Premiere OR AE)
      [4] In Premiere, put an "In" point on the raw footage side, and an "Out" point on the "replaced" side, and render this section
      http://i.imgur.com/wvEKbkF.png
      [5] Export using same settings as raw footage (h.264, sequence size, 12fps, ~2mbps)
      [6] Open export in Quicktime.
      Here is a (cropped, obviously) screen shot from the beginning of the clip (the raw footage):
      http://i.imgur.com/QVhA1TZ.png
      And here is that same area from the "replaced" side:
      http://i.imgur.com/vOrCD1D.png
      It is much softer.
      Does any one have any input as to why the mere use of this feature causes degredation in the image quality? Again, I have not added any effects.
