5 Replies Latest reply on Jul 10, 2017 9:39 AM by extendersGame
    How do I write a javascript code to open InDesign template, import XML, save and export to pdf?
    DeniseSSI
      I mostly need the help with writing the javascript code to open the InDesign file, import some xml that will be randomly coming in and then saving the document.
        • 1. Re: How do I write a javascript code to open InDesign template, import XML, save and export to pdf?
          Kai Rübsamen Adobe Community Professional
          Hi Denise, you can try something like that:
          main ()
          function main () {
              // create a path for a file object
              var curFile = File ( "~/Desktop/myTemplate.indt" );
              // check if the file exists
              if (!curFile.exists) {
                  alert ( "no template!" );
                  exit();
              // open the file
              var curDoc = app.open( curFile );
              // create a new file object
              var inddFile = new File ( curFile.parent + "/myName.indd" );
              // save the file
              curDoc.save( inddFile );
              //XML import
              curDoc.importXML( File("~/Desktop/myName.xml") );
              // root-element
              var root = curDoc.xmlElements[0];
              // do your xml stuff, e.g.
              var category = root.xmlElements[0]; // for more categories it needs a loop
              var product1 = category.xmlElements.itemByName('productname');
              product1.placeXML ( curTextFrame1 ); // there must be a textFrame!
              var pdfFile = new File ( curFile.parent + "/myName.pdf" );
              // export to pdf
              curDoc.exportFile( ExportFormat.PDF_TYPE, pdfFile );
          • 2. Re: How do I write a javascript code to open InDesign template, import XML, save and export to pdf?
            DeniseSSI Level 1
            Thank you. I will try your suggestion.
            Would there be a way to make the xml file coming in a variable ???
            We would be automating this to receive different named .xml files.....
            • 4. Re: How do I write a javascript code to open InDesign template, import XML, save and export to pdf?
              DeniseSSI Level 1
              I got it to work as is if I point to a "static" file on the desktop...What command would I use if I was going to use it in a workflow that would receive multiple xml files as different names. Basically how do I make
              //XML import     curDoc.importXML( File("~/Desktop/myName.xml") );"
              so that it accepts any incoming xml file???
              • 5. Re: How do I write a javascript code to open InDesign template, import XML, save and export to pdf?
                extendersGame Level 1
                If you want the code to run on multiple arbitrary xml files, the first thing you will need to do is store an array of file objects corresponding to the files you want processed. This can be done with an .opendlg selecting for all the xml files you want to run.
                var FilePath = new File("thePathToYourUnprocessedXMLfilesFolder");
                var xmlArray = FilePath.openDlg("Choose the XML FEED file(s)","*.xml",true);
                If you want to eliminate the need for a person to manually select the files, you can also tell the program to just run everything it finds in a given folder:
                var theXMLFolder = Folder("pathToFolder");
                var xmlArray = theXMLFolder.getFiles(); // The variable is now an array of path objects for the folder contents
                Once you have an array of the xml files you want to run, you will need to nest your code in a for loop:
                for(var arrayIndex = 0; arrayIndex < xmlArray.length; arrayIndex++){
                     // Do stuff with the xml data
                     // If it's a lot of files, you might want to automatically save/close the document after you are finished with it
                Just call all your code inside that loop replacing the static file path with: File (xmlArray[arrayIndex])
                Good practice bonus:
                I recommend also checking that the path object is an instance of a file with an xml extension so that if someone drops a folder or a text document in your hot folder, the system just ignores it. There is no property built in for the later check but this prototype placed at the top of your script should do the trick:
                // Add a file object command to display the file extension
                if (File.prototype.fileExt == null) File.prototype.fileExt = function(){return this.name.replace(/^.*\./,'')};
                so the for loop code should now look something like this:
                     if (xmlArray[arrayIndex] instanceof File) // Ignore folders
                          if(xmlArray[arrayIndex].fileExt () == "xml") // Ignore files that are not xml files
                This answer is probably too late for you but hope it helps someone in the long run.
