2 Replies Latest reply: Feb 16, 2014 3:06 AM by datauduong RSS
    How to fix issue of Image in Any PDF appear yellow
    datauduong Community Member
      I am trying to view Any PDF in Acrobat Reader, the image appear as light yellow.
      The following pdf is created by printing to a PDF Creator of a WebPage using IE.
      I've check this document on another machine with Similar Spec (Windows 8.1 Pro) and same Acrobat Reader version, it appear as gray as expected.
      Checked the same pdf on the machine having this issue using "FoxIt Reader" it appear as Normal(Gray).
      Image appear as yellow
      Image Appear Normal in FoxIt and PDF Xpansion Reader (Gray)
      I've tried the following options, but doesn't help:
      1. Edit > Preferences > Accessibility > Replace Document Colors (Doesn't Help)
      2. I have try and reset Windows Color Profile to the Default (Doesn't Help)
      Does any one know what would cause this problem?
      I've also tried Acrobat Pro (The same problem).
      Thanks.
      Regards Dat.
