3 Replies Latest reply on Feb 16, 2014 3:34 PM by amalankar
    Databases SQL help!
      when i connect mySQL databases to dreamweaver I only see the default databases, none of the ones I created in myPHPadmin, please advise.  I'm running MAMP on Mac OS X 10.7
        • 1. Re: Databases SQL help!
          es73 Level 2
          What version of DW are you using? I thgink I need more information - what are you doing to connect to your databases, and what are you expecting to see?
          • 2. Re: Databases SQL help!
            amalankar Level 1
            Sorry I should have included all that.  Dreamweaver CS6, I am going to the databases icon on the right side of the screen in "App Developer Plus" viewing mode.  I am trying to add a database  with mySQL connection:
            Connection Name: registration, mySQL server: localhost, Username: root, Password: my set password, Database <--- here is the error when I click select; it does not show the databaes I made in myPHP admin. called Registration and Dbank;  I'm expecting to see these databases as I can see them in myPHPadmin.  but in Dreamweaver after connecting to mySQL i only see: information_schema. mysql, performance_schema, and test.
            • 3. Re: Databases SQL help!
              amalankar Level 1
              i had installed mysql before installing MAMP, when I removed mysql, the databases no longer connected in dreamweaver.  I got an error:
              MySQL Error #2002
              No such file or directory I have tried
              1. Formating my computer and reinstalling all Dreamwweaver, MAMP, and re-enabling everything --> SAME ERROR
              2. Setting the path in terminal to include /Applications/MAMP/Library/bin/mysql in .bash_profile  --> SAME ERROR
              3. In Terminal doing:
              cd /var/
              sudo mkdir mysql
              cd (to get back to root)
              sudo ln -s /tmp/mysql.sock /var/mysql/mysql.sock
              --> SAME ERROR
              Why can't Dreamweaver just connect to the databases.? PLEASE HELP!
