1 Reply Latest reply on Jun 2, 2007 7:53 AM by Rothrock
    Flash compability
    IndieMonkey
      I have a scroll bar that loads text from a notepad file via xml. It counts lines and works great in an older version of Flash but when I try it in a newer version the scrollbar dosn't scroll properly. It's easier to explain if you take a look at the files for yourself:
      RIGHT CLICK HERE AND SAVE AS TO DOWNLOAD
      The original file that works fine is called scrollbar 1, the same thing in a newer flash is called scrollbar 2. I don't really know why it's doing this. Any ideas yo lot?
      Thanks for looking,
      Gavin
        • 1. Re: Flash compability
          Rothrock Level 5
          Someone might download it (I'm not), but it would be helpful if you did a little of the work yourself and shared it with us.
          Under what version of the player does it work? Six?
          Where does it stop working? Seven?
          Since it is called scroller does it have any code like:
          curposition += incrementPosition
          Does curposition start with a given value or not?
