2 Replies Latest reply on Jun 26, 2006 2:35 AM by Newsgroup_User
    Question about drop down list
    Level 7
      Hi there,
      I would like to creat an drop down list with Director's behavior. The list
      will use for (1) navigation & would like to be an "topic list" which means
      showing which section accordingly playing.
      Therefore i need the drop down menu automaticly roll to the "section name"
      which relative content is playing. Is it possible to SET the drop down list
      this way?
      Pls. advise.
      Thx a lot.
      Athena
        • 1. Re: Question about drop down list
          James Newton, ACP Level 3
          If you mean "marker name" when you say "section name", then the answer is easy.
          1) Create a Field member
          2) Drop the Field onto the Stage
          3) Drop the Dropdown List behavior onto the Field sprite
          4) In the Behavior Parameters Dialog, select Contents of this list: [Markers in this movie]
          5) Select Purpose of list: [Execute ... go marker ...]
          6) Run the movie and make a selection from the list
          • 2. Re: Question about drop down list
            Level 7
            hi there,
            Tried & it works.
            Thanks a lot~~
            Athena
            in article e7o8a4$j7h$1@forums.macromedia.com, openspark at
            webforumsuser@macromedia.com wrote on 6/26/06 5:10 PM:
            > easy.
            > in this movie]
