2 Replies Latest reply on Feb 16, 2014 4:03 PM by praguian
    Frame count differs between Premiere and AE
    praguian Level 1
      I rendered a PNG Sequence in AE that put out 10,299 images (frames).
      However, when I import that to Premiere, the sequence is only 8,591 frames long.
      The AE project was 720p and 25 FPS, and the Premiere sequence settings are the same.
      As far as I can tell, the entire render does play in Premiere; it just plays quicker...almost like it's actually in 30 FPS or something.
      And considering 8,591/10,299 is nearly the same ratio as 25/30, I'm guessing this is the case.
      So the question becomes, why is Premiere behaving like 30 FPS when its settings (below) are set to 25 FPS like the original AE project?
