6 Replies Latest reply on Feb 17, 2014 4:32 PM by A.T. Romano
    removing head switch noise from VHS video
    joeK
      Hi experts,
      I have imported a video from a vhs videorecorder - and now I want to remove the head switch noise by shifting the entire video 8 lines down and insert 8 lines black at the top and bottom.
      How do I do this with Premiere Elements 11?
      Thanks a lot for your help!
        • 1. Re: removing head switch noise from VHS video
          A.T. Romano Level 7
          joeK
          Are you referring to
          http://preservation.bavc.org/artifactatlas/index.php/Head_Switching_Noise
          Have you tried just clicking on the screen and using the handles on the bounding box of the image to scale it up a bit?
          ATR
          • 2. Re: removing head switch noise from VHS video
            joeK Level 1
            Hello ATR,
            thanks for your fast answer - I have exactly the problem which is
            described in the link you mailed.
            I have tried your suggested solution already - but unfortunatly the
            video quality is affected rather badly when I use the bounding box to
            zoom the video a little bit. Thats why I would like to do it without
            rescaling the entire video.
            I found the recommendation to do it in multiples of 8 lines in the
            internet - it was said that it will be best for the compression
            algorithm. Recommendation was: shift the entire video 8 lines down and
            add 8 lines "black" at the top and at the bottom.
            So how can this be done with Premiere Elements?
            Thanks again,
            Best regards,
            Joern
            Am 16.02.2014 21:16, schrieb A.T. Romano:
            created by A.T. Romano <http://forums.adobe.com/people/A.T.+Romano> in
            /Premiere Elements/ - View the full discussion
            <http://forums.adobe.com/message/6126425#6126425
            • 3. Re: removing head switch noise from VHS video
              the_wine_snob Level 9
              JoeK,
              If you can live with black bars, you can use the Effect>Crop, and only Crop those few lines of pixels on the bottom of the Frame.
              Another similar method would be to use the Fixed Effect>Position, to move the Video Frame down, effectively cropping the bottom, leaving a black bar at the top.
              • 4. Re: removing head switch noise from VHS video
                A.T. Romano Level 7
                joeK
                I think that the scale up  ever so little (with Constrain Proportions Off) would have been the best, but if your image has problems with that (and as Hunt says can live with black bars), then
                Approach 1 - On Screen Image Moved Down
                The just moving the screen image down far enough to hide the switch head noise at the bottom of the frame. To do that:
                a. Click on the image on screen, and use the mouse cursor to drag the image downward far enough to hide the switch head noise bar.
                or
                b. Highlight/select the Timeline clip, go to Applied Effects Tab/Applied Effects Palette/Motion Panel expanded, and increase the second value for Position to move the image downward on the screen.
                The black at the top of the image that you generate in this process is not the color black but rather the program using black to represent transparency.
                Before Position second value = 238.8 in this example
                After Position second value = 250.8 in this example
                Approach 2 - Cropping out Noise
                Go to xf Effects/Transform/Crop and drag the Crop Effect into the video on the Expert workspace Timeline. Then adjust the Left, Top, Right sliders so that the image is not cropped at any of those edges. Move the Bottom slider from 0 upward to replace the switch head noise with transparency/black border at bottom.
                Please review and then let us know the outcome.
                Any questions or if clarification needed, please do not hesitate to ask.
                Thank you.
                ATR
                • 5. Re: removing head switch noise from VHS video
                  joeK Level 1
                  ... just brillant - exactly what I was looking for. Thanks a lot!
                  Just one tiny question remains: When I apply the Effects/Transform/Crop
                  the shown cropped area is not quite equal to the cropped area in the
                  rendered final video. In the rendered video the cropped black bar is
                  much bigger. Is there a way to switch the crop-effect-sliders unit from
                  % to pixel ? (would be perfect - than I could enter exactly the number
                  of lines I want to crop)
                  Am 17.02.2014 19:45, schrieb A.T. Romano:
                  <http://forums.adobe.com/message/6129282#6129282
                  • 6. Re: removing head switch noise from VHS video
                    A.T. Romano Level 7
                    joeK
                    Check out the Premiere Elements Effects Reference for its description of Transform Clip versus Transform Crop.
                    http://help.adobe.com/en_US/premiereelements/using/WS4B8135DA-083C-42eb-B09E-65070ECBC889. html#WS44DE71A2-B004-4103-BD28-54BB1BB42A27
                    Excerpts
                    Clip (Windows only)
                    The Clip effect trims rows of pixels off the edges of a clip and replaces the trimmed areas with a specified background color. If you want Adobe Premiere Elements to automatically resize the trimmed clip to its original dimensions, use the Crop effect instead of the Clip effect
                    Crop
                    The Crop effect trims rows of pixels from the edges of a clip and, if you select the Zoom option, automatically resizes the trimmed clip to its original dimensions. Use the slider controls to crop each edge of the clip separately. You can crop by pixels or clip percentage.
                    So, that "You can crop in pixels or clip percentage" sounds good. But.... I cannot find a way to do that in Premiere Elements 11 or 12. See this thread here that came to the same end. SG advised the "math approach" as a workaround.
                    http://forums.adobe.com/thread/1136431
                    I am going to check versions of Premiere Elements 10, 9, 8, 7, and 4 to see if Crop ever did offer "by pixels or clip percentage".
                    More later.
                    ATR
