5 Replies Latest reply on Mar 12, 2014 12:24 AM by BEGINNER_X
    Anybody can help me for RTF conversion?
    hasvi Level 1
      Anybody can help me for RTF conversion for selected text frames only in Indesign by script
        • 1. Re: Anybody can help me for RTF conversion?
          BEGINNER_X Level 3
          Hi Hasvi,
          May the below code is useful, but ensure please select the text, not textframes.
          var myDocPath = myDoc.filePath;
          var myDocName = myDoc.name.split(".indd").join(".rtf")
          var mySelection = app.selection[0].contents;
          //~ alert("mySelection: " + mySelection)
          myFile = new File(myDocPath + "/" + myDocName);
          app.selection[0].exportFile(ExportFormat.rtf, myFile);
          Siraj
          • 2. Re: Anybody can help me for RTF conversion?
            hasvi Level 1
            Hi thanks for your swift reply, but I need RTF format with paragraph style name and content as like below:
            H1 => Introduction
            TX => Used for HIV infection in combination with other antiretroviral drugs
            Is this possible?
            • 3. Re: Anybody can help me for RTF conversion?
              BEGINNER_X Level 3
              Hi Hasvi,
              May this below coding used for the selection of particular contents or paragraphs.
              If you need a texFrame contents, then you have to use loop concept.
              var myPStyles = app.selection[0].paragraphs[0].appliedParagraphStyle.name;
              var myFinal = myPStyles + "\t\t" + mySelection;
              alert("myFinal: " + myFinal)
              var myTextFile = new File(myDocPath + "/" + myDocName);
              myTextFile.open("w")
              myTextFile.write(myFinal)
              myTextFile.close();
              alert("Process Completed")
              Siraj
              • 4. Re: Anybody can help me for RTF conversion?
                hasvi Level 1
                Hi its nice
                But I want it should be run for whole document. Not only for selection, is this possible?
                app.selection[0]
                thank you again
                • 5. Re: Anybody can help me for RTF conversion?
                  BEGINNER_X Level 3
                  Hi Hasvi,
                  May the below code helpful for you, Kindly check
                  var myDocName = myDoc.name.split(".indd").join(".txt")
                  var myParas = app.activeDocument.stories.everyItem().paragraphs.everyItem().getElements();
                  myArray = new Array();
                  alert("myParas: " + myParas.length)
                  for(i=0; i<  myParas.length; i++)
                  var myPStyles = myParas[i].appliedParagraphStyle.name;
                  var mySelection = myParas[i].lines[0].contents;
                  var myFinal = "PStyle: " + myPStyles + "\r" + "FirstLine: " + mySelection + "\r\r";
                  myArray.push(myFinal)
                  alert("myArray: " + myArray)
                  myTextFile.write(myArray)
                  myTextFile.close();
                  alert("Report Generated in Document Location")
                  If my reply helpful for you, then please click Helpful or Correct answer.
                  It will motivate all forum members.
                  Siraj
