1 Reply Latest reply on Feb 17, 2014 7:08 PM by hemanthR
    Problem with ==
    Diego Ioppolo Level 1
      I've inserted an if condition in tab "update" i need that timeline stops at some points only if it is in play and not in reverse play.
      So I can't do that with Triggers.
      I've set several expressions that doesn't works... so I did some debug and I discover that:
      If I wrote:
      if (sym.getPosition() == n)
      it works only if n=last frame of composition
      if it is not the timeline continue to play.
      But, If i set
      if (sym.getPosition() >= n)
      it stops.
      This is not what I need beacuse I've several similar point.
      In conclusion, seems that Edge Animate needs more than one time frame to recognize that a condition is verified.
      How can I fix it?
