3 Replies Latest reply on Feb 18, 2014 9:49 AM by W_J_T
    Shear / Skew using shear angle and axis angle
    mCharlesrk
      I want to skew/shear the selected object using shear angle and axis angle.
      I am using below code for shear the object,
      var skewMatrix = app.getIdentityMatrix();
      skewMatrix..mValueB = .5
      But i dont know how to apply the axis angle with this matrix.
      any hints?
        • 1. Re: Shear / Skew using shear angle and axis angle
          pixxxel schubser MVP & Adobe Community Professional
          Searching for "shear" gives you the answer.
          You can find a script snippet, written by CarlosCanto
          http://forums.adobe.com/message/5477878#5477878
          // skew or shear selection, carlos canto 07/04/13
          // http://forums.adobe.com/message/5475881#5475881
          var idoc = app.activeDocument;
          var sel = idoc.selection[0];
          var im = app.getIdentityMatrix();
          //im.mValueB = .5; // skew y 50%
          im.mValueC = .5; // skew x 50%
          sel.transform (im, true, true, true, true, 1, undefined);
          Have fun
          • 2. Re: Shear / Skew using shear angle and axis angle
            mCharlesrk Level 1
            Thanks for your response....
            This will shear the object horizantaly/Verticaly , but i need to know how to apply axis angle to shear the object.
            Update the matrix value c ( im.mValueC ) to Shear the object horizantaly
            Update the matrix value b ( im.mValueB) to Shear the object verticaly
            But, How to shear the object using axis angle. for example i want to skew the object by shear angle 147 degree with axis angle 18 degree.
            Thanks in advance.
            • 3. Re: Shear / Skew using shear angle and axis angle
              W_J_T Level 4
              Perhaps you want: concatenateRotationMatrix
              var doc = app.activeDocument;
              var sel = doc.selection[0];
              var m = app.getIdentityMatrix();
              m.mValueC = .5
              var m2 = concatenateRotationMatrix(m, 25);
              sel.transform(m2, true, true, true, true, 1, Transformation.CENTER);
              Hopefully that helps towards your desired end result?
