1. Re: Breeezy
R_Kelly Feb 17, 2014 7:40 PM (in response to StrongBeaver)See if unchecking Show warning when installing unsigned ZXP extensions in the cs5 extension manager preferences works.
(File>Preferences>Warnings)
If not, you probably need to have your internet turned on while installing the extension with the cs5 extension manager.
2. Re: Breeezy
StrongBeaver Feb 17, 2014 7:52 PM (in response to R_Kelly)Unchecking that option didn't solve the problem; unfortunately this computer doesn't have internet connection
3. Re: Breeezy
R_Kelly Feb 17, 2014 8:31 PM (in response to StrongBeaver)You might contact the extension maker (Breezy) and see if they can tell you how to do a manual install without using the cs5 extension manager.
Or perhaps someone in the extension manager forum would have some ideas.
http://forums.adobe.com/community/creativesuites/extensionmanager?view=discussions
4. Re: Breeezy
StrongBeaver Feb 17, 2014 8:38 PM (in response to R_Kelly)The author of the extension is not open to aid with any problems; I'll have to take the second route, thanxs
5. Re: Breeezy
Noel Carboni Feb 17, 2014 8:54 PM (in response to StrongBeaver)I hate to ask, because it's obvious, but I must: Did you press the [Install] button anyway?
-Noel
6. Re: Breeezy
StrongBeaver Feb 17, 2014 9:00 PM (in response to Noel Carboni)Of course, otherwise I wouldn't get the installing extension progress bar, before the error message.
7. Re: Breeezy
R_Kelly Feb 17, 2014 9:46 PM (in response to StrongBeaver)Hopefully this should work:
If you have 7zip, then extract the contents of the Breezy_v1.3_beta.zxp
(or change the extension from .zxp to .zip and then extract the contents using windows default zip extractor)
Inside the extracted folder you'll see a Breezy.zxp.
Run the cs5 extension manager As an Adminstrator, click on the Install button, navigate to the Breezy.zxp and when
the dialog about the warning pops up click on Install
8. Re: Breeezy
Carl Sun Feb 17, 2014 10:33 PM (in response to StrongBeaver)Replied at http://forums.adobe.com/message/6131085#6131085.
9. Re: Breeezy
StrongBeaver Aug 10, 2014 12:37 PM (in response to StrongBeaver)I need to update this thread, the author of this great tool for pre-CC users is only available on Twitter and I'm not on Twitter. Therefore does anyone else experience this, especially on PsCS5 after installing the plug-in there is an error; this following file is missing bgoqaumf.dll when starting PsCS5 ?
