1 Reply Latest reply on Feb 17, 2014 11:41 PM by Willam van Weelden
    Any way to search places where a style is used in RH?
    kdeuler Level 1
      Hi
      I've a few questions about style management:
      1. Is there a way to search for where a style is used in a project or topic?
      2. If so, is there a way to search-and-replace, ie, find where a style is used and replace it with another style?
      3. When deleting a style, is there a way RH can be set to display a warning if the style to be deleted is being used anywhere?
      FrameMaker handles the above use cases very well. However, I can't yet see how these actions are done in RH.
      Thanks!
      -Kurt
        • 1. Re: Any way to search places where a style is used in RH?
          Willam van Weelden Level 5
          RH doesn't warn you if you delete a style that is in use.
          If you want to replace a specific style with another one, the easiest
          way is to use a search and replace operation. For example, to change the
          style 'myStyle1' into 'myStyle2', use the following search action:
          class="myStyle1"
          and replace by
          class="myStyle2"
          Make a backup before doing this though, as you can cripple a project in
          seconds.
          Kind regards,
          Willam
