Thanks for your suggestions guys,
Both of your suggestions have lead me to this question.
My path to the upload folder looks like this,
"www.mywebsite.com/projectname/imgs/photos/ ". Every example I have
seen, has been to use a full path starting with c:/.
Does it matter that I'm using a domain name as the path?
Here is what I got back from the <cfrethrow> tag;
Security: The requested template has been denied access to
http:\www.mywebsite.com\projectname\imgs\photos.
The following is the internal exception message: access
denied (java.io.FilePermission
http:\www.mywebsite.com\projectname\imgs\photos read)
Resources:
Enable Robust Exception Information to provide greater detail
about the source of errors. In the Administrator, click Debugging
& Logging > Debugging Settings, and select the Robust
Exception Information option.
Check the ColdFusion documentation to verify that you are
using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1;
SV1; .NET CLR 1.1.4322)
Remote Address 61.228.89.11
Referrer
http://www.mywebsite.com/projectname/admin/addEntry.cfm
Date/Time 27-Jun-06 07:47 PM
I noticed that on the error page, the directory that has
denied acces only has 1 "\" after the http:
I've double checked my code, and both "\"'s are there.
Could that be the problem?
Thanks for any help you can offer, this thing is driving me
crazy. ;)
- J
