1 Reply Latest reply on Jun 28, 2006 9:56 AM by ntsiii
    Flex, ActionScript and the Slide class
    clsimeone Level 1
      I hope someone can help me solve a problem...
      I'm using the flex SwfLoader to load a flash side presentation as follows...
      <mx:SWFLoader id="ss_slides" source="ss_slides.swf" width="320" height="240"/>
      I would like to access the flash "Slide Class" using flex so I can make the following call...
      Slide.gotoNextSlide();
      Anyone know how I can do that? Would it be through the SwfLoader Object? Is there another way?
      F.Y.I. Here is a snippets about the Slide class from the Flash 8 help...
      Using the Slide class (Flash Professional only)
      You use the methods and properties of the Slide class to control slide presentations you create using the Screen Outline pane for a Flash Slide Presentation, to get information about a slide presentation (for example, to determine the number of child slides contained by parent slide), or to navigate between slides in a slide presentation (for example, to create "Next slide" and "Previous slide" buttons).
      You can also use the built-in behaviors that are available in the Behaviors panel to control slide presentations. For more information, see Adding controls to screens using behaviors (Flash Professional only) in Using Flash.
      Chris S.
