10 Replies Latest reply on Aug 5, 2006 1:35 PM by Orr_4
    need Help with Linking Question
    Orr_4 Level 1
      Not quite sure how to do this.
      I have a gallery page of thumbnails that I want to reference a different layout page for the individual image.
      What I want to happen is, when you click the thumbnail on the thumbnail gallery page, a new layout page opens in the same browser window with that thumbnails larger image. I know how to link the new .html page , or the larger image, But I don't know how to link them both so they both open?
      I have many images and pages of thumbnails that I have to do this with.
      Thanks for any help
        • 1. Re: need Help with Linking Question
          Level 7
          You want the new page to replace the current page in the browser viewport?
          I guess I don't understand what "both" is?
          Murray --- ICQ 71997575
          Adobe Community Expert
          (If you *MUST* email me, don't LAUGH when you do so!)
          http://www.dreamweavermx-templates.com - Template Triage!
          http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
          http://www.dwfaq.com - DW FAQs, Tutorials & Resources
          http://www.macromedia.com/support/search/ - Macromedia (MM) Technotes
          "Orr 4" <webforumsuser@macromedia.com> wrote in message
          news:eb26ps$mlp$1@forums.macromedia.com...
          > larger
          > Thanks for any help
          • 2. need Help with Linking Question
            Orr_4 Level 1
            Let me try to explain it better.
            I have a "gallery page" with 20 thumbs on it.
            I have another page designed " frame page " to replace the ' gallery page / thumb page" in order to display the enlarged view of the thumbnail selected, only 1 image will show on this page.
            Now, what I don't know how to do is to have this happen.
            When you click on 1 of the thumbnails on the gallery thumbnail page, the page is replaced with the " frame page "
            AND the larger image of the thumb that was clicked on is loaded with the frame page.
            Does that make it any clearer?
            I understand how to link to the frame page, What I don't know how to do is link the appropriate image with the frame page.
            • 3. Re: need Help with Linking Question
              Level 7
              Link from the thumb to the page containing the larger image and make the
              target of the link be the name of the frame containing the thumb page.
              news:eb2cu9$t2r$1@forums.macromedia.com...
              > selected,
              > page
              > frame page.
              • 4. need Help with Linking Question
                Orr_4 Level 1
                I'm not sure i'm clear or understand.
                The page for the enlarged image, "frame page" has an empty container for the larger image to fit into.
                When I select the thumb on the "gallery page" in the properties window below I have the
                "Link" to the Framepage .html
                What should the target be set to? _blank _parent _self or _top
                The Low Src should then be linked to the Image.jpg?
                I have tried several settings but the large image does not load?
                thks for helping
                • 5. Re: need Help with Linking Question
                  Level 7
                  You're wanting to use a single page as the only recipient of all of the
                  enlarged images, as opposed to having a separate page for each enlarged
                  image? You'd have to either use custom javascript or server-side code to
                  accomplish that.
                  news:eb2m63$9vc$1@forums.macromedia.com...
                  > the
                  > below
                  > I have the
                  > thks for helping
                  • 6. need Help with Linking Question
                    Orr_4 Level 1
                    image?
                    Yes as I have a hundred or so images. Having a devoted page for each image would be the wrong way to do this with so many images, don't you think?
                    Is there a better way?
                    accomplish that.
                    I'm a novice at this, would this be difficult ?
                    If not can you explain how to do it??
                    thanks
                    • 7. Re: need Help with Linking Question
                      Level 7
                      > image?
                      > would be the wrong way to do this with so many images, don't you think? Is
                      > there a better way?
                      > accomplish that.
                      > I'm a novice at this, would this be dificult ?
                      Is it absolutely necessary to have the full size images appear in
                      another page - could the page perhaps be worked so that the full size
                      images are contained within - if so then check out these....
                      http://www.fourlevel.com/dreamweaver/extensions/loadimage/example2.htm
                      and....
                      http://www.projectseven.com/tutorials/images/showpic/index.htm
                      there are commercial alternative at both the above sites too and theres
                      this extension too which may do the trick for you better than the two
                      above - this more or less does exactly what you want..
                      http://www.valleywebdesigns.com/vwd_jspw3.asp
                      HTH
                      chin chin
                      Sinclair
                      • 8. Re: need Help with Linking Question
                        Orr_4 Level 1
                        Actually the pages are the exact same except for the thumbnail area section which is being replaced on the new page with the image.
                        I don't have any problem with just exchanging the thumb area with the image in the same page if that makes things easyer.
                        I will try and get something up soon to make it easyer to refer to.
                        • 9. Re: need Help with Linking Question
                          Level 7
                          Investigate the free ShowPic extension from PVII as a way of doing that -
                          news:eb2p9m$d8p$1@forums.macromedia.com...
                          > section
                          > image in
                          • 10. Re: need Help with Linking Question
                            Orr_4 Level 1
                            Thanks guys
                            this http://www.valleywebdesigns.com/vwd_jspw3.asp looks to be the best solution for my needs I think. Just having the picture load over the thumbs with control over the looks of the window seems like a good way to go.
