3 Replies Latest reply on Feb 23, 2014 6:13 PM by Carl Sun
    Extension Manager CC problem
    At0micSilenCe
      so i got Photoshop CC and Lightroom    and i wanted to install some extensions in Photoshop but my Extension Manager CC hasn't found any application so what can i do to change this?
      i already looked around a bit and the FAQ toold me that i should start ExtendScript Toolkit CC and type in "BridgeTalk.__diagnostics__;"  and i should  check the path's but i couldn't find any path's at all
      here is the text i got from typing "BridgeTalk.__diagnostics__;" :
                Info:
                          Name = estoolkit-4.0
                          Status = PUMPING
                          Path
                          Version = 2.0
                          Build = ES 4.5.5
                          Next serial number = 18
                          Logging: = OFF
                          Now = 00:53:16
                                    Message Version = 2.05
                                    Authentication = ON
                                    Digest = ON
                Thread: estoolkit-4.0#thread
                          Avg. pump interval = 44ms
                          Last pump = 44ms ago
                          Ping: 7
                                    ECHO_REQUEST: ECHO_RESPONSE
                                              Timeout = undefined
                                              Handler = undefined
                                    STATUS: PUMPING
                                              Timeout = undefined
                                              Handler = undefined
                                    MAIN: MAIN
                                              Timeout = undefined
                                              Handler = installed
                                    LAUNCHED: LAUNCHED
                                              Timeout = undefined
                                              Handler = installed
                                    DIAGNOSTICS: DIAGNOSTICS
                                              Timeout = undefined
                                              Handler = installed
                                    INFO: INFO
                                              Timeout = undefined
                                              Handler = installed
                                    SETUPTIME: thread=0ms, left=0ms
                                              Timeout = undefined
                                              Handler = undefined
                Instances: 3
                          estoolkit-4.0#dbg:
                                              msg[00:53:16]: 00000013
                                                        @BT>Version = 2.05
                                                        Target = estoolkit-4.0#dbg
                                                        Sender = estoolkit-4.0#dbg
                                                        Sender-ID = localhost:win7512
                                                        Timeout = 01:53:17
                                                        Type = Ignore
                                                        Response-Request = Timeout
                                                        Headers = (no headers)
                                                        Timestamp = 00:53:16
                                                        Serial-Number = 13
                                                        Received = undefined
                                                        Result = undefined
                                                        Error = undefined
                                                        Body = (empty)
                                    Incoming: 1
                                    Outgoing: 0
                                    Handler: 9
                                              ExtendScript = for all messages
                                              Error = for only msg #3
                                              Error = for only msg #5
                                              Error = for only msg #9
                                              Result = for only msg #13
                                              Error = for only msg #13
                                              Timeout = for only msg #13
                                              Result = for only msg #15
                                              Error = for only msg #15
                          estoolkit-4.0#estk:
                                              msg[00:53:16]: 00000015
                                                        @BT>Version = 2.05
                                                        Target = estoolkit-4.0#estk
                                                        Timeout = 01:03:16
                                                        Type = Debug
                                                        Response-Request = Result Error
                                                        Serial-Number = 15
                                                        Result = undefined
                                                        Error = undefined
                                                        Body: 107 bytes
        Text = <get-properties engine="main" object="$.global" exclude="undefined,builtin,prototype" all="true" max="20"/>
                                    Incoming: 1
                                    Outgoing: 0
                                    Handler: 1
                          estoolkit-4.0: (main)
                                    Incoming: 0
                                    Outgoing: 0
                                    Handler: 1
      so if any one could help me would be nice
