4 Replies Latest reply on Feb 20, 2014 11:20 AM by Bjorn Kvinge
    Hidden fields does not appear as usual???
    Bjorn Kvinge Level 1
      Hi!
      My form does not work today as it used to...
      I have show/hide fields on certain values, and it does not work today.
      The hidden fields should appear when I choose anything else then "other" from the dropbox.
      Could someone please take a look at my form, please?
      it's important that my forms is up and running.
      Regards
      Bjørn
        • 1. Re: Hidden fields does not appear as usual???
          DevRandy Adobe Employee
          Hi!
          We did release an upgrade to hidden field handling.  Perhaps you are seeing an issue related to the change.
          Can you post your form URL so I can take a look?  Or send the URL in an email using the 'Send as email' link in the Actions on the right.
          -DevRandy
          • 2. Re: Hidden fields does not appear as usual???
            Hi!
            Yes I guess I see an issue.
            I have tried different combinations, and they works fine.
            Could the problem be with the "Other" choice.
            I have set it to show fields when not "Other".
            I have removed the hidden/show function from my forms until there is a fix...
            Regards
            Bjørn
            • 3. Re: Hidden fields does not appear as usual???
              Bjørn,
              With the latest release, the 'other' choice handling in form rules is broken.  Engineering has a fix that is working its way through our system and it will be released to the public in the next couple of weeks.
              In the meantime, it may be possible for you to change the rule to factor out the 'other' choice.  For instance, if your rule was show a field if the drop down value is not 'other', you could try show a field if the drop down value is value 1, value 2, ... or value n.  You could also try to hide a field if the drop down value is not value 1, not value 2, ... and not value n.
              I realize the solution is more complicated than your original rule and may not provide the behavior you are looking for.
              My appologies for the inconvenience,
              -DevRandy
              • 4. Re: Hidden fields does not appear as usual???
                Hi!
                Thanks for the suggestions.
                But I'll just wait until the fix will come.
                hmm.. If I only could make the rules with more then or less then...
                And one more thing.
                Can I find a update/release note every time there's an update?
                I saved this link ones, but I can't say it's informative on updates...
                Maybe if I click through all content I might find some new things.
                https://www.acrobat.com/formscentral/nb_NO/whats-new.html
                Regards
                Bjørn
                Message was edited by: Bjorn Kvinge
