1 Reply Latest reply on Feb 19, 2014 11:17 AM by resdesign
    Change image source distorts new image
    Matbathome
      Is there any easy way, once I change image source in Edge Animate, to get it to at least be proportionally correct? When I change an image source with a different size, it comes in distorted.
        • 1. Re: Change image source distorts new image
          resdesign Adobe Community Professional & MVP
          If you change the source it will fill the boundaries of the original source image automatically. If the size is different, it is probably better to delete the original image and drop the new one.
          If you are talking about loading an image dynamically and changing them dynamically, use css background image with no-repeat and have you div be the size of the largest image used unless you code the image size when they change.
