5 Replies Latest reply on Feb 19, 2014 12:15 PM by JimDamrau
    spry menu overlap
    JimDamrau
      horizontal spry menu which has submenus is being overlapped by another div. How do you get the menu to display over the second div?
        • 1. Re: spry menu overlap
          Jon Fritz II Adobe Community Professional & MVP
          Depending on how you have it set up, it could be as simple as adding a z-index setting to the menu.
          Could you post a link?
          • 2. Re: spry menu overlap
            JimDamrau Level 1
            Jon;
            Unfortunately I cannot as the page is behind a firewall. But what I can do is provide the code for the page.  Interesting enough if I view it in the Dreamweaver application is looks fine but when I look at it in IE the submenu appears behind the second DIV.
            <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> <title>CSDB Templates </title> <link rel="stylesheet" href="emx_nav_left.css" type="text/css"> <script src="SpryAssets/SpryMenuBar.js" type="text/javascript"></script> <link href="SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css"> </head> <body> <div id="masthead"> <h1 id="siteName">Radiant Mercury Customer Support Site</h1> <div id="utility">   <table width="75%" border="0" cellspacing="0" cellpadding="0">   <tr><td>     <div align="center">       <% if Session("MM_UserAuthorization") <> "" Then %>
                  Logout
                  <% Else %>
                  Login
                  <% End if %>     </div></td>   </tr> </table>   </div>     <ul id="MenuBar1" class="MenuBarHorizontal">        <li>[Item 1 | #]          <ul>            <li>[Item 1.1 | #]</li>            <li>[Item 1.2 | #]</li>            <li>[Item 1.3 | #]</li>          </ul>        </li>        <li>[Item 2 | #]</li>        <li>[Item 3 | #]          <ul>            <li>[Item 3.1 | #]              <ul>                <li>[Item 3.1.1 | #]</li>                <li>[Item 3.1.2 | #]</li>              </ul>            </li>            <li>[Item 3.2 | #]</li>            <li>[Item 3.3 | #]</li>          </ul>        </li>        <li>[Item 4 | #]</li>     </ul>     <form id="search" method="get" action="cust_listing.asp?custname=Request(searchfor)">       <input name="custname" type="text" id="custname" size="10">       <input name="Search" type="submit" id="Search" value="Search">     </form> </div> <!-- end masthead --> <div id="pagecell1">
              <!pagecell1>
            main area
                About Us |Site
            Map
            | Privacy Policy | CSDB Change  Request | Help Support | Lockheed Martin</div>
            </div>
            <!end pagecell1>
            var MenuBar1 = new Spry.Widget.MenuBar("MenuBar1", );
            </script>
            </body>
            </html>
            The style sheet emx_nav_left.css is as follows:
            /* emx_nav_left.css                            */
            /* Use with template Halo_leftNav.html         */
            /* HTML tag styles                             */
            body{
                            font-family: Arial,sans-serif;
                            color: #333333;
                            line-height: 1.166;
                            margin: 0px;
                            padding: 0px;
                            background: #cccccc url("bg_grad.jpg") fixed;
            /******* hyperlink and anchor tag styles *******/
            a:link, a:visited
            a:hover{
                            text-decoration: underline;
            /************** header tag styles **************/
            h1
            h2
            h3
            h4
            h5
            /*************** list tag styles ***************/
            ul{
            list-style-type: square;
            ul ul{
            list-style-type: disc;
            ul ul ul{
            list-style-type: none;
            /********* form and related tag styles *********/
            form
            label
            input{
            /* Layout Divs                                 */
            #pagecell1
            #tl
            #tr
            #masthead
            #pageNav
            #content
            /* Component Divs                              */
            #siteName
            /************** utility styles *****************/
            #utility
            #utility a
            #utility a:hover{
            /************** pageName styles ****************/
            #pageName
            #pageName h2
            #pageName img
            /************* globalNav styles ****************/
            #globalNav
            #globalNav img{
                            margin-bottom: -4px;
            #gnl
            #gnr
            #globalLink
            a.glink, a.glink:visited{
                            font-size: 9pt;
                            color: #000000;
                            font-weight: bold;
                            margin: 0px;
                            padding: 2px 5px 4px 5px;
                            border-right: 1px solid #8FB8BC;
            a.glink:hover{
                            background-image:  url("glblnav_selected.gif");
                            text-decoration: none;
            .skipLinks
            /************ subglobalNav styles **************/
            .subglobalNav
            .subglobalNav a:link, .subglobalNav a:visited {
                            font-size: 80%;
                            color: #ffffff;
            .subglobalNav a:hover
            /*************** search styles *****************/
            #search
            #search input{
              font-size: 70%;
              margin: 0px  0px 0px 10px;
            #search a:link, #search a:visited {
                            font-size: 80%;
                            font-weight: bold;
            #search a:hover
            /************* breadCrumb styles ***************/
            #breadCrumb
            #breadCrumb a
            #breadCrumb a:hover
            /************** feature styles *****************/
            .feature
            html>body .feature
            .feature h3
            .feature img
            /*************** story styles ******************/
            .story
            .story h3
            .story p
            .story a.capsule
            .story a.capsule:hover{
            td.storyLeft{
                            padding-right: 12px;
            /************** siteInfo styles ****************/
            #siteInfo
            #siteInfo img
            /************ sectionLinks styles **************/
            #sectionLinks
            #sectionLinks h3
            #sectionLinks a:link, #sectionLinks a:visited
            #sectionLinks a:hover{
                            border-top: 1px solid #cccccc;
                            background-color: #DDEEFF;
                            background-image: none;
                            font-weight: bold;
            /************* relatedLinks styles **************/
            .relatedLinks
            .relatedLinks h3
            .relatedLinks a
            /**************** advert styles *****************/
            #advert
            #advert img
            /********************* end **********************/
            Please let me know if you need any additional information.
            Thanks for your help.
            James A Damrau
            Lockheed Martin
            Radiant Mercury Program
            IS&GS
            303-932-4448
            • 3. Re: spry menu overlap
              JimDamrau Level 1
              Jon;
              Sorry I should have included the code for the template. Here it is
              function menu(allitems,thisitem,startstate){
              callname= "gl"+thisitem;
              divname="subglobal"+thisitem;
              this.numberofmenuitems = 13;
              this.caller = document.getElementById(callname);
              this.thediv = document.getElementById(divname);
              this.thediv.style.visibility = startstate;
              function ehandler(event,theobj){
                for (var i=1; i<= theobj.numberofmenuitems; i++){
                  var shutdiv =eval( "menuitem"i".thediv");
                  shutdiv.style.visibility="hidden";
                theobj.thediv.style.visibility="visible";
              function closesubnav(event){
                if ((event.clientY <48)||(event.clientY > 107)){
                  for (var i=1; i<= numofitems; i++){
                    var shutdiv =eval('menuitem'i'.thediv');
                    shutdiv.style.visibility='hidden';
              .style2 {font-size: small}
              .style3 {font-weight: bold}
              .style4
              </style> <link href="../SpryAssets/SpryMenuBarHorizontal.css" rel="stylesheet" type="text/css"> </head> <!-- DW6 --> <body> <div id="masthead"> <h1 id="siteName">Radiant Mercury Customer Support Site</h1> <div id="utility">   <table width="75%" border="0" cellspacing="0" cellpadding="0">   <tr><td>     <div align="center">       <% if Session("MM_UserAuthorization") <> "" Then %>
                    Logout
                    <% Else %>
                    Login
                    <% End if %>     </div></td>   </tr> </table>   </div>     <ul id="MenuBar1" class="MenuBarHorizontal">        <li>[Item 1 | #]          <ul>            <li>[Item 1.1 | #]</li>            <li>[Item 1.2 | #]</li>            <li>[Item 1.3 | #]</li>          </ul>        </li>        <li>[Item 2 | #]</li>        <li>[Item 3 | #]          <ul>            <li>[Item 3.1 | #]              <ul>                <li>[Item 3.1.1 | #]</li>                <li>[Item 3.1.2 | #]</li>              </ul>            </li>            <li>[Item 3.2 | #]</li>            <li>[Item 3.3 | #]</li>          </ul>        </li>        <li>[Item 4 | #]</li>     </ul>     <form id="search" method="get" action="../cust_listing.asp?custname=Request(searchfor)">       <input name="custname" type="text" id="custname" size="10">       <input name="Search" type="submit" id="Search" value="Search">     </form> </div> <!-- end masthead --> <div id="pagecell1">
                <!pagecell1>
              main area
                  About Us |Site
              Map
              </div>
              <!end pagecell1>
              </script>
              </body>
              </html>
              James A Damrau
              Lockheed Martin
              IS&GS
              303-932-4448
              • 4. Re: spry menu overlap
                Could you come to the forum itself in a browser and repost your code?
                Email responses with code get messed up.
                • 5. Re: spry menu overlap
                  JimDamrau Level 1
                  This is the page source code
                              Logout            Login
                  main area
                  This is the emx_nav_left.css code /***********************************************/ /* emx_nav_left.css                            */ /* Use with template Halo_leftNav.html        */ /***********************************************/ /***********************************************/ /* HTML tag styles                            */ /***********************************************/ body{ font-family: Arial,sans-serif; color: #333333; line-height: 1.166; margin: 0px; padding: 0px; background: #cccccc url("bg_grad.jpg") fixed; } /******* hyperlink and anchor tag styles *******/ a:link, a:visited{ color: #005FA9; text-decoration: none; } a:hover{ text-decoration: underline; } /************** header tag styles **************/ h1{ font: bold 120% Arial,sans-serif; color: #334d55; margin: 0px; padding: 0px; } h2{ font: bold 114% Arial,sans-serif; color: #006699; margin: 0px; padding: 0px; } h3{ font: bold 100% Arial,sans-serif; color: #334d55; margin: 0px; padding: 0px; } h4{ font: 100% Arial,sans-serif; color: #333333; margin: 0px; padding: 0px; } h5{ font: 100% Arial,sans-serif; color: #334d55; margin: 0px; padding: 0px; } /*************** list tag styles ***************/ ul{ list-style-type: square; } ul ul{ list-style-type: disc; } ul ul ul{ list-style-type: none; } /********* form and related tag styles *********/ form { margin: 0; padding: 0; } label{ font: bold 1em Arial,sans-serif; color: #334d55; } input{ font-family: Arial,sans-serif; } /***********************************************/ /* Layout Divs                                */ /***********************************************/ #pagecell1{ position:absolute; top: 112px; left: 2%; right: 2%; width:95.6%; background-color: #ffffff; } #tl { position:absolute; top: -1px; left: -1px; margin: 0px; padding: 0px; z-index: 100; } #tr { position:absolute; top: -1px; right: -1px; margin: 0px; padding: 0px; z-index: 100; } #masthead{ position: absolute; top: 0px; left: 2%; right: 2%; width:1346px; height: 75px; visibility: visible; } #pageNav{ float: left; width:178px; padding: 0px; background-color: #F5f7f7; border-right: 1px solid #cccccc; border-bottom: 1px solid #cccccc; font: small Verdana,sans-serif; } #content{ padding: 0px 10px 0px 0px; margin:0px 0px 0px 178px; border-left: 1px solid #ccd2d2; } /***********************************************/ /* Component Divs                              */ /***********************************************/ #siteName{ margin: 0px; padding: 16px 0px 8px 0px; color: #ffffff; font-weight: normal; } /************** utility styles *****************/ #utility{ font: 75% Verdana,sans-serif; position: absolute; top: 14px; right: 0px; color: #919999; left: 845px; } #utility a{ color: #ffffff; } #utility a:hover{ text-decoration: underline; } /************** pageName styles ****************/ #pageName{ padding: 0px 0px 14px 10px; margin: 0px; border-bottom:1px solid #ccd2d2; } #pageName h2{ font: bold 175% Arial,sans-serif; color: #000000; margin:0px; padding: 0px; } #pageName img{ position: absolute; top: 14px; right: 6px; padding: 0px; margin: 0px; left: 622px; width: 124px; height: 38px; background-image: url(../Sunset.jpg); } /************* globalNav styles ****************/ #globalNav{ position: relative; width: 100%; min-width: 640px; height: 32px; color: #cccccc; padding: 0px; margin: 0px; background-image:  url("glbnav_background.gif"); } #globalNav img{ margin-bottom: -4px; } #gnl { position: absolute; top: 0px; left:0px; } #gnr { position: absolute; top: 0px; right:0px; } #globalLink{ position: absolute; top: 6px; height: 22px; min-width: 900px; padding: 0px; margin: 0px; left: 10px; z-index: 100; width: 1209px; } a.glink, a.glink:visited{   font-size: 9pt;   color: #000000; font-weight: bold; margin: 0px; padding: 2px 5px 4px 5px; border-right: 1px solid #8FB8BC; } a.glink:hover{   background-image:  url("glblnav_selected.gif"); text-decoration: none; } .skipLinks {display: none;} /************ subglobalNav styles **************/ .subglobalNav{ position: absolute; top: 84px; left: 0px; /*width: 100%;*/ min-width: 640px; height: 20px; padding: 0px 0px 0px 10px; visibility: hidden; color: #ffffff; } .subglobalNav a:link, .subglobalNav a:visited { font-size: 80%; color: #ffffff; } .subglobalNav a:hover{ color: #cccccc; } /*************** search styles *****************/ #search{ position: absolute; top: 5px; right: 10px; z-index: 101; } #search input{   font-size: 70%;   margin: 0px  0px 0px 10px; } #search a:link, #search a:visited { font-size: 80%; font-weight: bold; } #search a:hover{ margin: 0px; } /************* breadCrumb styles ***************/ #breadCrumb{ padding: 5px 0px 5px 10px; font: small Verdana,sans-serif; color: #AAAAAA; } #breadCrumb a{ color: #AAAAAA; } #breadCrumb a:hover{ color: #005FA9; text-decoration: underline; } /************** feature styles *****************/ .feature{ padding: 0px 0px 10px 10px; font-size: 80%; min-height: 200px; height: 200px; } html>body .feature {height: auto;} .feature h3{ font: bold 175% Arial,sans-serif; color: #000000; padding: 30px 0px 5px 0px; } .feature img{ float: left; padding: 0px 10px 0px 0px; } /*************** story styles ******************/ .story { padding: 10px 0px 0px 10px; font-size: 80%; } .story h3{ font: bold 125% Arial,sans-serif; color: #000000; } .story p { padding: 0px 0px 10px 0px; } .story a.capsule{ font: bold 1em Arial,sans-serif; color: #005FA9; display:block; padding-bottom: 5px; } .story a.capsule:hover{ text-decoration: underline; } td.storyLeft{ padding-right: 12px; } /************** siteInfo styles ****************/ #siteInfo{ clear: both; border-top: 1px solid #cccccc; font-size: small; color: #cccccc; padding: 10px 10px 10px 10px; margin-top: 0px; } #siteInfo img{ padding: 4px 4px 4px 0px; vertical-align: middle; } /************ sectionLinks styles **************/ #sectionLinks{ margin: 0px; padding: 0px; } #sectionLinks h3{ padding: 10px 0px 2px 10px; border-bottom: 1px solid #cccccc; } #sectionLinks a:link, #sectionLinks a:visited { display: block; border-top: 1px solid #ffffff; border-bottom: 1px solid #cccccc; background-image:  url("bg_nav.jpg"); font-weight: bold; padding: 3px 0px 3px 10px; color: #21536A; } #sectionLinks a:hover{ border-top: 1px solid #cccccc; background-color: #DDEEFF; background-image: none; font-weight: bold; text-decoration: none; } /************* relatedLinks styles **************/ .relatedLinks{ margin: 0px; padding: 0px 0px 10px 10px; border-bottom: 1px solid #cccccc; } .relatedLinks h3{ padding: 10px 0px 2px 0px; } .relatedLinks a{ display: block; } /**************** advert styles *****************/ #advert{ padding: 10px; } #advert img{ display: block; } /********************* end **********************/ This is the template code (csdb_spry.dwt) /***********************************************/ /* emx_nav_left.css                            */ /* Use with template Halo_leftNav.html        */ /***********************************************/ /***********************************************/ /* HTML tag styles                            */ /***********************************************/ body{ font-family: Arial,sans-serif; color: #333333; line-height: 1.166; margin: 0px; padding: 0px; background: #cccccc url("bg_grad.jpg") fixed; } /******* hyperlink and anchor tag styles *******/ a:link, a:visited{ color: #005FA9; text-decoration: none; } a:hover{ text-decoration: underline; } /************** header tag styles **************/ h1{ font: bold 120% Arial,sans-serif; color: #334d55; margin: 0px; padding: 0px; } h2{ font: bold 114% Arial,sans-serif; color: #006699; margin: 0px; padding: 0px; } h3{ font: bold 100% Arial,sans-serif; color: #334d55; margin: 0px; padding: 0px; } h4{ font: 100% Arial,sans-serif; color: #333333; margin: 0px; padding: 0px; } h5{ font: 100% Arial,sans-serif; color: #334d55; margin: 0px; padding: 0px; } /*************** list tag styles ***************/ ul{ list-style-type: square; } ul ul{ list-style-type: disc; } ul ul ul{ list-style-type: none; } /********* form and related tag styles *********/ form { margin: 0; padding: 0; } label{ font: bold 1em Arial,sans-serif; color: #334d55; } input{ font-family: Arial,sans-serif; } /***********************************************/ /* Layout Divs                                */ /***********************************************/ #pagecell1{ position:absolute; top: 112px; left: 2%; right: 2%; width:95.6%; background-color: #ffffff; } #tl { position:absolute; top: -1px; left: -1px; margin: 0px; padding: 0px; z-index: 100; } #tr { position:absolute; top: -1px; right: -1px; margin: 0px; padding: 0px; z-index: 100; } #masthead{ position: absolute; top: 0px; left: 2%; right: 2%; width:1346px; height: 75px; visibility: visible; } #pageNav{ float: left; width:178px; padding: 0px; background-color: #F5f7f7; border-right: 1px solid #cccccc; border-bottom: 1px solid #cccccc; font: small Verdana,sans-serif; } #content{ padding: 0px 10px 0px 0px; margin:0px 0px 0px 178px; border-left: 1px solid #ccd2d2; } /***********************************************/ /* Component Divs                              */ /***********************************************/ #siteName{ margin: 0px; padding: 16px 0px 8px 0px; color: #ffffff; font-weight: normal; } /************** utility styles *****************/ #utility{ font: 75% Verdana,sans-serif; position: absolute; top: 14px; right: 0px; color: #919999; left: 845px; } #utility a{ color: #ffffff; } #utility a:hover{ text-decoration: underline; } /************** pageName styles ****************/ #pageName{ padding: 0px 0px 14px 10px; margin: 0px; border-bottom:1px solid #ccd2d2; } #pageName h2{ font: bold 175% Arial,sans-serif; color: #000000; margin:0px; padding: 0px; } #pageName img{ position: absolute; top: 14px; right: 6px; padding: 0px; margin: 0px; left: 622px; width: 124px; height: 38px; background-image: url(../Sunset.jpg); } /************* globalNav styles ****************/ #globalNav{ position: relative; width: 100%; min-width: 640px; height: 32px; color: #cccccc; padding: 0px; margin: 0px; background-image:  url("glbnav_background.gif"); } #globalNav img{ margin-bottom: -4px; } #gnl { position: absolute; top: 0px; left:0px; } #gnr { position: absolute; top: 0px; right:0px; } #globalLink{ position: absolute; top: 6px; height: 22px; min-width: 900px; padding: 0px; margin: 0px; left: 10px; z-index: 100; width: 1209px; } a.glink, a.glink:visited{   font-size: 9pt;   color: #000000; font-weight: bold; margin: 0px; padding: 2px 5px 4px 5px; border-right: 1px solid #8FB8BC; } a.glink:hover{   background-image:  url("glblnav_selected.gif"); text-decoration: none; } .skipLinks {display: none;} /************ subglobalNav styles **************/ .subglobalNav{ position: absolute; top: 84px; left: 0px; /*width: 100%;*/ min-width: 640px; height: 20px; padding: 0px 0px 0px 10px; visibility: hidden; color: #ffffff; } .subglobalNav a:link, .subglobalNav a:visited { font-size: 80%; color: #ffffff; } .subglobalNav a:hover{ color: #cccccc; } /*************** search styles *****************/ #search{ position: absolute; top: 5px; right: 10px; z-index: 101; } #search input{   font-size: 70%;   margin: 0px  0px 0px 10px; } #search a:link, #search a:visited { font-size: 80%; font-weight: bold; } #search a:hover{ margin: 0px; } /************* breadCrumb styles ***************/ #breadCrumb{ padding: 5px 0px 5px 10px; font: small Verdana,sans-serif; color: #AAAAAA; } #breadCrumb a{ color: #AAAAAA; } #breadCrumb a:hover{ color: #005FA9; text-decoration: underline; } /************** feature styles *****************/ .feature{ padding: 0px 0px 10px 10px; font-size: 80%; min-height: 200px; height: 200px; } html>body .feature {height: auto;} .feature h3{ font: bold 175% Arial,sans-serif; color: #000000; padding: 30px 0px 5px 0px; } .feature img{ float: left; padding: 0px 10px 0px 0px; } /*************** story styles ******************/ .story { padding: 10px 0px 0px 10px; font-size: 80%; } .story h3{ font: bold 125% Arial,sans-serif; color: #000000; } .story p { padding: 0px 0px 10px 0px; } .story a.capsule{ font: bold 1em Arial,sans-serif; color: #005FA9; display:block; padding-bottom: 5px; } .story a.capsule:hover{ text-decoration: underline; } td.storyLeft{ padding-right: 12px; } /************** siteInfo styles ****************/ #siteInfo{ clear: both; border-top: 1px solid #cccccc; font-size: small; color: #cccccc; padding: 10px 10px 10px 10px; margin-top: 0px; } #siteInfo img{ padding: 4px 4px 4px 0px; vertical-align: middle; } /************ sectionLinks styles **************/ #sectionLinks{ margin: 0px; padding: 0px; } #sectionLinks h3{ padding: 10px 0px 2px 10px; border-bottom: 1px solid #cccccc; } #sectionLinks a:link, #sectionLinks a:visited { display: block; border-top: 1px solid #ffffff; border-bottom: 1px solid #cccccc; background-image:  url("bg_nav.jpg"); font-weight: bold; padding: 3px 0px 3px 10px; color: #21536A; } #sectionLinks a:hover{ border-top: 1px solid #cccccc; background-color: #DDEEFF; background-image: none; font-weight: bold; text-decoration: none; } /************* relatedLinks styles **************/ .relatedLinks{ margin: 0px; padding: 0px 0px 10px 10px; border-bottom: 1px solid #cccccc; } .relatedLinks h3{ padding: 10px 0px 2px 0px; } .relatedLinks a{ display: block; } /**************** advert styles *****************/ #advert{ padding: 10px; } #advert img{ display: block; } /********************* end **********************/ The appearnace of the menu works fine in the Dreamweaver View mode but when viewed in IE 8.0 the submenus appear below the pagecell1 DIV. Thanks!
