1 Reply Latest reply on Feb 20, 2014 6:08 AM by Magus069
    If then statement calculation
    webnetworksmd
      I am having difficulty getting a statement to work.  Basically I want to have field 1 take "x" value and then return an "x" value in Field 2. 3 options for field 1 that returns the value of that option into field 2.
      This is what I have that returns errors:
      If (Field 1 eq "A") then (Field 2 eq "10")
      elseif
      If (Field 1 eq "B") then (Field 2 eq "8")
      elseif
      If (Field 1 eq "C") then (Field 2 eq "6")
      endif
      Can someone help me with the correct syntax to perform this operation? I am sure I have something wrong somewhere. Or maybe I am using the wrong type of statements for this operation.
      Thank you!
      Tom
        • 1. Re: If then statement calculation
          Magus069 Level 4
          1. You can't have a 'elseif' followed by an 'If' because your 'elseif' is already an 'If' statement
          2.FormCalc 'if' statement operators are used as letters, so to have 'equal to' is 'eq', to have 'lower than' is 'lt', to have 'greater than' is 'gt', to have 'lower or equal to' is 'le'... etc...
          To assign a value to a field or variable you must use the '=' sign
          If (Field1 eq "A") then
               Field2 = "10"
          elseif (Field1 eq "B") then
               Field2 = "8"
          elseif (Field1 eq "C") then
               Field2 = "6"
          endif
